Question about EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
P4m2668233 audio sound - EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard
MY DELL PC HAVE SOUND DRIVERS WHICH ARE NOT WORKING AND ONCE I INSTALL NEW SOUND DRIVER THEY SOUND AT A VERY LOW VOICE EVEN WHEN THE VOLUME IS ADJUSTE TO THE HIGHEST
Hi antonykionyo
DELL OPTIPLEX GX60 DESKTOP PC AUDIO/SOUND DRIVER
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System, consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question, including information about your Operating System.
Check the status of the Audio Device and the Audio Driver in Device Manager.
Start > (My) Computer > (System Properties) View System Settings > Device Manager
This will tell you if the Audio/Sound Device is installed and functioning properly and if the Audio/Sound Driver is installed properly. If a red 'x' or a yellow question or exclamation mark appears next to the Audio/Sound Device, then there is probably a settings anomaly, fault, error or conflict with the Audio Device and/or its Driver.
AUDIO DEVICE SETTINGS
For your Audio/Sound Device to function properly, it must be set as the Default Device:
Start > Control Panel > (Hardware and Sound) Sounds Speech and Audio Devices > Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the Drop Down Menu to the right of "Sound Playback - Default Device" (preferred Default Playback Device) > select "ADI 198x Integrated Audio" > Apply > OK > Restart computer.
AUDIO/SOUND DRIVER PROBLEMS
Re-install the correct Audio/Sound Driver that relates to both the Audio/Sound Device (ADI 198x Integrated Audio) and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the Dell Drivers and Utilities CD or from the official Dell support website here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R71579&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=92933
If your Operating System is not the original Windows 2000 or Windows XP for which this PC was designed, then it is highly probable that no Audio/Sound Driver exists for that Operating System.
If you are committed to both this PC and an unsupported Operating System but all the other Devices and their Drivers are functioning normally except the Audio Device or you are using Win 2000 or Win XP but the Audio/Sound Problem remains unsolvable (faulty Audio/Sound Chip), then consider buying and installing either an internal 5.1, 7.1 or 8.1 PCI Sound Card or an external USB Sound Card that is pre-confirmed as being compatible with your Operating System. They can all be inexpensive. See examples here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=5.1+7.1+8.1+pci+soundcard&x=5&y=17
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 24, 2011 | Dell Optiplex GX60 PC Desktop
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
I cant hear nothings on my computer theirs no sound it says theirs is no speakers or headphones plugged in and wel they are plugged in (compaq presario SR5202HM) windows 7 ultimate 32 bit.
are you using a sound Card the presario SR5202HM has this sound setup
Sound/Audio Integrated Realtek ALC888 Audio
  • Audio CODEC: Realtek ALC888
  • High Definition 6 channel audio
make sure that this sound driver is up to date
here is the plugs
4 - Audio: Line In (light blue) 5 - Audio: Line Out (lime) 6 - Audio: Microphone (pink) make sure you have the headphones plugged into the Lime colored plug
if this doesn't work i have some more idea's let me know.
Jan 23, 2011 | Compaq Audio card Sound Card
Where can i download p4m2668233 motherboard driver?
http://www.bioticaindia.com/p4m266-8233.html
or
driver
byte.com
Jan 30, 2010 | Intel Motherboard
HD Audio Render problem with microphone
Good day Sir, I had a HD audio render as my sound card on my windows xp2.In my sound and audio devices properties, my sound playback is on HD audio render and my sound recording is on HD audio capture.The problem is that I had no sounds on my microphone. Thank You. Joseph Huenda
Nov 24, 2008 | Radio Communications
Sound msi 640
If your problem in your computer is no sound, just insert the cd installer on your motherboard, then select audio that if your sound is on board, if sound card, insert the cd installer for audio then select audio.
Hope that will solve your problem
Thanks
Nov 12, 2008 | Compaq Audio card Sound Card
Sound and audio devices problem
all the options in sound and audio device properties are in active no sound is heard
Dec 17, 2007 | Edirol UA-4FX External Sound System
EliteGroup Via P4M266A (P4VMM2 V7.3) Motherboard Logo
14 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
