I need a wiring diagram for a miller 2 ton electric heating and cooling for a moble home
WhiteRussian
  • 167 Answers
SOURCE: changing home thermostat
Couldn't find your thermostat based off the information you provided; find the model number and follow the link to the Contractor Support Page.
White-Rodgers Multi-Stage Thermostate Diagrams for Contractors
Posted on Nov 28, 2008
  • 85 Answers
SOURCE: will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Posted on Dec 06, 2008
farfield
  • 462 Answers
SOURCE: need wiring diagram for 1980's 3 ton package unit
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
Posted on May 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: i need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 06, 2009
wise_jf
  • 66 Answers
SOURCE: wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
Posted on Jun 30, 2010
I have an older Norton 20KW electric furnace and I would like to know where to get a wiring diagram. I cannot get the fan to fun on E heat but it runs at any other setting.
In the tstat find a setting for electric heat also/or tstat controls the fan (not equipment) Good luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 29, 2017 | Heating & Cooling
12 ton carrier package unit wiring diagram
heating or cooling mode? The wireing diagram is on the back of the electrical access door.
Jan 26, 2014 | Heating & Cooling
Intertherm moble home furnace My heat strips came on one night while my a/c was running. We awoke to 101* temps. I removed the orange...
Sounds like a bad sequencer (the thing you unplugged the wire from probalbly). It will have 24vac supplied to the heating element in the sequencer and most likely 240vac being passed by the sequencer to the heat strips. This parts are not very expensive and can be purchased at a heating and air supply or a mobile home supply company. You can turn off the power and use an ohmmeter to figure out which one is bad. There may be only one or there may be 2 or 3. Let me know what you find.
Oct 25, 2010 | Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
I need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
Jun 05, 2009 | Heating & Cooling
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
