Question about BenQ FP71G 17" LCD Monitor
Fix monitor screen goes black after 2 seconds
2 Suggested Answers
  • 18 Answers
SOURCE: Monitor blue light comes on,
I have had this problem before and had to contact the manufacturer. I was able to send them back and the manufacturer sent me a replacement. If your monitor is under warranty it should not cost you anything.
Posted on Mar 15, 2011
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
Recently when I boot up my computer I get the monitor to display an image for about 2 seconds and then it goes to a black screen. if I unplug the monitor from the back of the computer and plug it back in,...
The capacitors for the power source are failing. This causes a short burst of power to get to the lamps, but then they cannot hold a charge to continuously power the lamps. You will have to replace the monitor. I suggest checking your warranty status and replacing the monitor.
Jul 19, 2011 | Gateway FPD2275W LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Black screen
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Restart!
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen goes black after 2 seconds
This could be one of two problems, the light in your monitor has a loose cable, or the light is dying. I have seen cold cathode lights that are about 10-15$ to buy and many instructions on putting them in yourself.
Solution 2, your cable is loose on the back of the monitor. Make sure you have the screws tightened on either side of the vga or dvi cable, both on the back of your monitor and on the back of your computer or laptop.
Jun 28, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Viewsonic monitor goes black one second after startup screen boots up. Fix for this? thanks
plz log in safe mode and then disable the display adapter from the device monitor then log back normally and check whether problem is solved or not
Apr 29, 2009 | Computers & Internet
BenQ FP71G 17" LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
