It run good we turned it off and now it want come back on
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
Dash lights turned off one night while driving my ford telstar. What's wrong
Turn on headlights ,go to back of car and see if you have running lights ,if not check your fuse its probably bad. usually running lights and dash lights are on the same fuse. if this was helpful please leave good feed back
Oct 15, 2014 | Cars & Trucks
It doesn't turn on no more it was running good and it stop
The fuse is located on back wall on the heater element at the 2 oclock position.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 24, 2013 | Dryers
Husqvarna 455 rancher turn on side then back upright give throttle it dies
is the fuel filter stuck in the tank not allowing it to stay in the fuel when you turn it on it's side?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 15, 2013 | Husqvarna Garden
What`s the standard setting for a mixure screw on a 1969 Suzuki TS 250?
If your talking about air fuel mixture screw a good place to start is turn screw clockwise till stops.back out 1 1/2 turns get bike running see how throttle responce is.If bike is still sluggish then try 1/2 turn increaments counterclock wise till bike runs smooth.Good luck ...Brian
May 09, 2011 | 1971 Suzuki T 350
Air screws 600 katana how many turns?
Back the screw out a quarter of an inch. That is your starting point. After you do that with the bike running slowly back the screw out until it starts running good, then keep turning it until it starts to run bad again then stop and turn it back in 1/4 of an inch and you should have your optimal setting.
Apr 07, 2010 | 1991 Suzuki GSX 600 F (Katana)
Starting a 2002 Dodge Neon in extremely cold weather
The best is to turn the key on to the run position for a few seconds then back off then back to run and then start. This cycles the fuel pump and sends a good supply of fuel up to the injectors. Also do not rev the engine excessively until it has warmed up to allow oil to flow good.
Good luck, dont forget to rate.
Jan 05, 2010 | 2000 Dodge Neon
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
Won't start. i changed spark plug and cleaned carb. it was starting but running at half speed. then it just quit and won't start at all now
You might want to try adjusting the carb. Remove the two caps on the screws and turn each screw in 1/2 turn. Then try to start. If it starts then you are good to go. If not try turning in a little more. Once you get it started you might need to back the screw back out a little to get the unit to run "smoothly" once done just put the caps back on or discard (you don't need them.
Mike
May 01, 2009 | Homelite Consumer Products MightyLite...
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
