Question about Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
How do I fix filter light on - Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
How do you fix the light in a Pur faucet filter
It could be mineralized, try soaking it in vinegar or scale remover.
Mar 03, 2017 | Refrigerators
How to fix the filter indicator light?
Sure there is no other blockage in the water line? did you put the filter in correct? everything connected as it should be? just to hide a few possibilities. Officers there could be more wrong, but now you have a start.
Mar 31, 2015 | Samsung RF4287HA
How do i reset water filter red light
on most maytag /jen-air. products if you push the light and the lock together to reset the replace filter light .. hope this hepled mm ( Majic **** ) thanks for using fix ya
Oct 24, 2010 | Jenn-Air JCD2389G Side by Side...
The change filter light didn't go off after changing the filter also
after changing the filter try holding the the lock and light button for 4 to 5 sec this should reser the filter light . mm feed back pls and thanks for ysng fix ya .
Oct 21, 2010 | Jenn-Air 42" Side-By-Side Built-In...
Water Filter Alarm Light
TRY to unplug for 5 minutes and replug it back in that should clear the code and if it does not repost a comment it here to fix it. Hopes this
fix the problem. Avid101
Jul 09, 2009 | Refrigerators
Eco and Fast lights flashing
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
Jul 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
http://www.partselect.com/water-filter+reset-change-filter-light+repair.htm
May 18, 2008 | Refrigerators
Filter light - Samsung RS21DNS
I would try changing filter and see if that fixes the light problem... How long has it been since it was changed?
Sep 17, 2007 | Samsung RS2534 Side by Side Refrigerator
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
26 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
