Question about Lilly Pulitzer Water Sport
How many lilly pulitzer paddle boards were made for Gifts with Purchase of $3000?
How to send gifts to the mother on Mothers day???
On Mothers day, every child will give gifts to their mother. For sending gifts to the mother, Countryoven is the best website. This site helps you in sending good gifts. Mother Day Gifts
Apr 15, 2016 | Happy Mother's Day Most Beautiful Gifts
How to prune arum lilly
Anon an Arum Lilly is a bulb. Just take the dead flower heads off when they finish flowering and then let the foliage die back naturally
Aug 30, 2014 | Garden
Where is the best place to stand on a paddle board?
When paddle boarding, you should stand in the middle of the board. The nose end (front) should not be sticking out of the water and the tail should not be digging into the water.
Jan 17, 2013 | Water Sport
Can I remove my fins on my paddle board?
The fins can be easily removed to transporting the paddle board, however they are used for navigation of the water so you should not try to paddle board without the fins attached.
How should I choose the size of my paddle board?
Paddle boards come in three sizes 10ft, 11ft and 12ft, the size is determined by the weight of the person and how many paddles there will be as well as how far the paddler wants to glide between paddles. Normally a person weighing less than 160lbs will choose the 10ft board and someone weighing over 160lbs would take the 11ft. If the paddler is heaver let's say 300lbs or they want to have more than one paddler they would take the 12ft board.
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
IS there a place that lists spreader settings for the scotts turf builder drop spreader? Are they the same as any of the other more commonly listed spreaders? I want to spread some Lilly Miller Moss Out...
If the product you are planning on applying has a spreader setting for a Scotts AccuGreen, or  specifically for the AccuGreen 3000; you can use that recommendation in your Turf Builder Classic Drop Spreader.  If they do not have a suggested spreader setting for the Accugreen, or  Accugreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Jan 30, 2011 | Scotts Company Scotts Turf Builder Classic...
We broke the control lever that allows the scooter to go frontward and backward. What is the part and how can we get it.
The Golden Buzzaround Lite Scooter (I am not sure of the RTO prefix) is manufactured by
Golden technologies. If you broke the control lever (paddle) for the throttle potentiometer, there is probably also damage to the potentiometer. I recommend you replace the paddle and potentiometer. See page 16 at the following link:
http://www.goldentech.com/pdf/support/ride/gb101-service-manual.pdf
This is a simple repair that should take under 1 hour. It's a little tricky to center the paddle by loosening and tightening the allen set screws.
Please purchase OEM parts for this scooter to get the correct parts and fit. Please consult the manufacturer:
Golden Technologies • 401 Bridge Street, Old Forge PA 18518 • Tel: (800) 624-6374 • Fax: (800) 628-5165 • www.goldentech.com
They may require you to purchase from an authorized local dealer.
A partial parts list is available at this link:
http://www.goldentech.com/pdf/support/ride/BuzzaroundParts.pdf
You can save considerably on the labor cost if you replace this part yourself. Work slowly and carefully so you do not damage the internal circuit board or pinch any wires on assembly. Use the correct size allen wrench so you do not strip the screws when removing the paddle lever. Hope this helps.
Nov 26, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Water Sport Logo
581 people viewed this question
Top Lilly Pulitzer Water Sport Experts
Bill Boyd
Tom Chichester
Are you a Lilly Pulitzer Water Sport Expert? Answer questions, earn points and help others
