Question about Northstar Garden
North star 22112
Need a manual
What is the moon crescent and the north star called
North Star is called Polaris - see the short story by H.P. Lovecraft.
Jan 02, 2017 | Optics
Will hood from 1999 north star deville will fix on 2001 north star deville car?
No. The 99 Deville was the same from 1997-99 and the front end changed in 2000. The 2001 will be the same 2000-05 and comes with or without hood ornament. Hope this helps.
Feb 02, 2015 | Cars & Trucks
Bh north america
If you haven't already, try this phone # for BH North America
(949) 206-0330
Dec 01, 2013 | Exercise & Fitness
How does a compass always point to due north?
"Due North," by definition, is the direction towards the earth's north pole; or, visually at night, towards Polaris, the north star. Therefore, compasses generally do NOT point towards due North but, rather, point towards "magnetic north," as the other responder described, which is a variably located at some distance from True North, depending upon where the north-locating compass is situated on our planet. In most circumstances magnetic North is close enough so that people are willing to accept it as North in general terms. However, depending on your location, and upon seasonal changes caused by Earth's wobbling rotation (called precession) true North can be many degrees off from magnetic (from your compass's) North. In those cases true North must be determined using declination charts, which will tell you how many degrees to add or subtract on you compass in order to determine true North by the Magnetic North your compass is pointing to. For example, if magnetic North is 10 degrees west of true North at your compass's location (that is, your compass is actually pointing 10 degrees to the "left" of North), then you would correct by considering the +10-degree bearing point on your compass dial as True North--and, likewise, add 10 degrees to any bearing line you happen to determine using your compass. You have one other way of finding True North, which is celestially, by sighting towards the Pole star, aka Polaris, aka the North Star...that is, providing that the sky is UNcloudy and unsunny enough for the star to be visible. Of course, that only works for those located in the morthern hemisphere. Those south of the equator have a "south pole" star but it is not as accurate as Polaris in the northern hemisphere.
Jul 09, 2012 | Camping, Backpacking & Hiking
I need a picture/or diagram of the serpentine belt routing on a 1998 Cadillac 4.6l north star engine. Car is a De ville
I need a diagram of how to replace a serpentine belt on a 1998 Calilic 4.61 north star engine
Dec 22, 2009 | 1998 Cadillac DeVille
Access to odd numbered spark plugs on North-Star V8
To gain access you have to remove the ignition coil pack. There are only 4 10mm bolts holding it on. Also remove the cross over to have more room.
Oct 31, 2009 | 1998 Cadillac DeVille
HOW DO I USE A BUSHNELL NORTH STAR 787880 TELESCOPE
Here are the manuals that you can download for free--
http://www.opticsplanet.net/bushnell-warranty.html#manuals
May 16, 2009 | Bushnell Optics
I need simple set up instructions for australia
All GOTO scopes require a setup routine-- on my ETX 90 I must--
1. Train the drives
2. Set the time and the date, and the observing site in the hand controller
3. Level the tripod and the tube
4. Point the tube NORTH
5. And align and center on two stars BEFORE the telescope will find anything.
Read the manual TWICE--- and then practice inside before you take it outside at night.
Apr 04, 2009 | Bushnell North Star 78-8850 Telescope
Garden Logo
81 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
