Question about Fedders A3X05F2A Air Conditioner
Where is the drain pan on a Fedders air conditioner?
RepairUSA
  • 50 Answers
SOURCE: drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Posted on Aug 10, 2007
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
  • 1165 Answers
SOURCE: need a fan motor for fedders model A6Y18F7B 18000
Easiest thing to do is pull the motor out and take it to Grainger. They can probably match it with a Dayton brand. No HVAC place will sell you a motor. They are all wholesale, and not to the public. You really don't have a whole lot of options here.
Good Luck
Posted on Feb 21, 2009
  • 10865 Answers
SOURCE: what is the air exchanger (open or closed) switch for?
The air exchanger is there to give you the option of adding fresh outdoor air [open] or recirculate the air in the room [closed].
Posted on Jun 04, 2009
  • 34 Answers
SOURCE: can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
Posted on May 21, 2010
Why is water leaking from unit
The drain is plugged up. This causes water to overflow out of the drain pan and on to the floor. Water comes from the evaporator coil, when it condenses water vapor out of the air to remove humidity. If the drain is not plugged up, then the air conditioner is not level. Meaning it is tilted forward or backwards enough so that the water cannot reach the drain properly and it overflows onto the floor.
May 18, 2014 | Fedders A6P09S2A Air Conditioner
Where is fedders 5000 btu drain plug
If you have a window unit or thru the wall unit, Drain Hole is located under the drip pan at near the rear of the unit. It may be difficult to find if it is clogged. As the clog will blend in wit the hole.
Hope this helps you locate it. Thanks for choosing FixYa.
Aug 24, 2011 | Fedders A3X05F2C Air Conditioner
My air conditioner is leaking water from the front side just below the control panel....what is causing this?
2 things generally cause this.
1. The rear of the unit is not tilted down enough for the water to flow to the drain hole in the drip pan.. 1/4' to 1/2" tilt is the general rule of thumb.
2. The drain hole at the rear of the drip pan is clogged and needs to be cleared. It can be hard to find, as the clog will blend in with the drain. Use a pipe cleaner to clear the clog.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Fedders AER08F2A Air Conditioner
Fedders AC leaking water from front, older model was in storage. Cant find the manual to make sure it's installed proper, or see if we need to clean somehting out. It leaks when it's running, then...
The unit needs to be tilted down 1/4/" to 1/2" on the outside of the window. Also check the drain pan's drain hole, under the unit (outside the window) for clogs. Doing all of this should solve the problem.
Jul 11, 2011 | Fedders AEQ07FBG Air Conditioner
Leaking inside. Fedders A3X05F2A-J Unit is sloped away from house. Have sprayed coils. Doesn't seem to be drain hole at back of unit
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Fedders A3X05F2A Air Conditioner
A6K32E7C part number for kit to keep water from blowing out thru the evaporator
you may just need to pull the unit out and clean the small drain pipe that goes from the evap pan its the pan under the front coil and should drain toward the back of the a/c toward the condensor coil ..the coil on the back of the unit
Sep 30, 2010 | Fedders A6K32E7C Thru-Wall/Window Air...
Where are the drain ports on a Fedders A3XO5F2E-A My unit is leaking water on the floor even though it is tilted down. ...
The drain holes are in the back corners of the pan...and they will plug with dirt...to get to them you will need to slide the unit out of the chassis if it is that type or pull the whole unit out so you can take the cover off and open the holes...
Then you will be back in business again..
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 15, 2010 | Fedders AEY12F7F Wall/Window Air...
Where is the drain pan for condensation? When we use the unit my carpet ends up wet.
the drain "pan" is located below the coil in the fromn of the unit...there may be a hose that travels accross the bottom of the unit to the back , that could be clogged, also it is important that the unit is correctly pitched to the outside so that the water will drain towards the window and not on the carpet...
Aug 15, 2009 | Fedders A6P09S2A Air Conditioner
Drain pan fills quickly
Aug 09, 2007 | Fedders A6P09S2A Air Conditioner
Fedders A3X05F2A Air Conditioner Logo
37 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
