Question about Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
Motor hums but does not pump - Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
  • 10,865 Answers
Unplug the pump and spin it by hand. Then plug it back in and it may take off. If it does not you will have to have the pump rebuilt or replaced.
Posted on Jun 23, 2009
Motor hums but won't kick on
motor high limits tripping defective motor replace motor or whole pump
Jun 14, 2014 | Pentair 1 HP Challenger Pump
Pump relay
if relay is humming bad relay if pump motor humming need new motor
Jun 08, 2013 | AO Smith Pool & Spa
How do you reset spa motor/pump?
Most of the motors have an internal device called a clixon that detects excessive current and shuts off the motor. It then turns it on again when it cools off. If you wait and wait and there is power for sure at the motor terminals and the motor is not even humming then there is a problem in the motor. If it hums for a few seconds and quits humming for a while then the motor capacitor is bad or the motor is bad. I hope this helps.
Aug 13, 2011 | Pool & Spa
Motor hums attemps to turn but does not
If motor hums and does not rotate, the motor winding is bad.
Motor is overheating and will stop humming and it will not work again.
30 years ago, motors were rewound at local electric shop.
Today the copper winding and steel parts are recycled or thrown into landfill.
Check warranty papers and then buy new pump.
Apr 18, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
The pump just hums when plugged in
hi, the motor has windings that can go bad in time. this hum you are hearing is called a A.C. hum. this will occur when the motor windings are bad. you will need to replace the pump motor. this will fix this issue.
Mar 10, 2009 | Garden
Motor hums when turned on
Try this link for help. They suggest emailing before calling:
http://www.mypool.com/introduction.htm
Feb 24, 2009 | A.O. Smith SQ1102 Pool Pump Motor
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 | Garden
DISHWASHER DRAMA
If you can hear the drain motor humming, look for a clog in the air gap. That's the silver dome on the back of the sink. If there's nothing there, you'll have to find the clog inside the bottom of the dishwasher.
Remove the bottom rack. Rotate the short tube that the lower spray arm is connected to about 1/4 turn clockwise and remove the lower spray arm. Remove the screens over the pump assembly. The hole to the drain pump is on the bottom right. If the motor hums, but doesn't pump, and there's no clog, the pump must be replaced.
If the motor doesn't hum in the drain mode, check for power at the pump with a voltmeter. the pump is behind the toe panel on the left. Reaching the terminals to take a reading may be difficult. you can disconnect the terminals from the pump to take the reading only if you use rubberized alligator clips to connect to the wires. If the motor has power but doesn't hum, replace the motor. If there's no power to the motor, replace the electronic control / timer.
Mar 11, 2008 | Dishwashers
Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor  for 56j Frame Motors Ust1152 Logo
592 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
