Question about Uniden Bearcat Model Bc142xl 10 Channel Scanning Radio Scanner Bc-142xl Manual
I lost all channels and I can't reprogram them.
When I follow the instructions, and review, all digits keyed in are zero.
Central doorlock not working
in the event of a faulty/lost remote control or flat battery, the system can be overidden using two methods depending on the build date of the vehicle. up to september 1999 the ignition key overides the system after that date the digital key overide. The ignition key overide is in the form of a code of 5 digets recorded on a card and attached to owners manual. At the back. Code is also recorded on a tag with ignition key. If lost refer to dealer
Nov 28, 2012 | 2012 Hyundai Accent
Regency R1077 base scanner can not delete old frequencies to reprogram scanner
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
Jul 11, 2011 | Radio Shack Pro-96 Scanner
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
1. the newstar universal tv remote contrlol i bought, cannot change the channel, although i can use the adding/minus the volume. 2. in as much as wanted to use also for te change of channel, i follow...
Unfortunately, universal remotes often do not work as well as the packaging says.... but all hope is not lost.
First, try ALL the programming codes listed for your brand of TV. Often, one will work. Be sure to follow the programming instructions, which usually have you trying the POWER ON/OFF button first after reprogramming.
If that fails, most universal remotes have a "scan" feature that, when you start it, will cycle through every code it has stored. During a "scan" you keep the remote pointed at the set and when the set powers off, you hit the ENTER key (or the key specified in the remote manual) to stop the scan and test the functioning of your remote (channel +/-, VOL +/-, etc.)- it takes a long time and can get frustrating, but keep trying and you should find a set of codes that will operate your TV correctly.
If you have no luck, do not give up hope completely- I would next recommend that you purchase a Philips brand universal remote- this is the brand that I have found to be most flexible.
Mar 02, 2011 | Televison & Video
Lost my key
If you have another key then you can buy a blank transponder key for $16 here:
http://www.autotransponder.com/2005_jeep_grand_cherokee_key_blank_transponder_chip_1
You will get all instructions how to reprogram the key by yourself too.
If you lost the only key you had, then go to the Chrysler dealer. You have to show them a picture ID, and the car ownership (TITLE). Is going to cost you around $50. They will provide you a hard copy of instruction how to reprogram it.
Oct 23, 2010 | 2005 Jeep Grand Cherokee
Lost digital channels+hdmi
should have to do with the re reprogramming get your manual and try to reprogram the channels such as cable or tv or cable tv or dtv just make sure you choose the one with cable and dtv
Feb 25, 2010 | LG 37LC2D Television
Appears to be no way to retune the digital channels on a sony kd-28dl1ou digi tv
1) make sure u on digital!
2) press key to left of no. zero on zapper ( has ? above)
3) press Blue for setup
4) from menu go for auto tune & follow instructs.
5) exit via Red
Sep 30, 2009 | Sony Televison & Video
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
Zero halliburton triple combination lock instructions manual
Depress the square release button, just to the right of the 3 dials on outside of the case, while providing an upward pressure on the small tab on the inside of the case just behind the 3 dials. Now select your new combination by selecting new digits for each dial.
Dec 15, 2008 | Cameras
Remote code
1. programed RCVR with code 0314
2. then assigned a key (such as the TV/VCR key) with the EFC number of 300
3. then reprogramed RCVR w/ code 0027
498 "surround mode"
568 "+10"
578 "band"
370 "stereo"
702 "6"
444 "4"
447 "2"
317 "8"
701 "0" (zero)
450 "7"
704 "5"
707 "3"
449 "1"
577 "9"
384 "tape 2"
252 "mute"
255 "vol down"
512 "power"
515 "vol up"
572 "channel down"
257 "channel up"
Try This an see if works
Oct 19, 2008 | Kenwood VR-209 Receiver
Uniden Bearcat Model Bc142xl 10 Channel Scanning Radio Scanner Bc-142xl Manual Logo
55 people viewed this question
Top Uniden Office Equipment & Supplies Experts
Lawrence Oravetz
ka4iup
ka4iup
Are you an Uniden Office Equipment and Supply Expert? Answer questions, earn points and help others
