Question about HP Pavilion ze4400 Notebook
Problem with HP laptop - starting on for a second and then dying
I have a laptop HP pavilion ze4400 with AMD Athlon processor, which I bought 5 years ago. When i try to start it, it flashes for a second, the fan starts rotating, but all of a sudden everything goes off... Even for under a second... No sound, nothing on the screen - just a moment flash and off... the problem started to happen when i dissambled the laptop in order to put some paste above the processor, cause it was all dried out and the laptop was heating up like a hot-plate... so much, that it would just turn off at some point, after working for an hour or so (on AC power, battery is generally gone already)... So after i put the paste and put on the flat metal covering above the processor, which is connected with the fan, my problems started... I tried to reset the laptop, tried to replace the battery (the small one on the MB), but nothing helps... I'm at a loss.
If somebody has some idea, please advice, Thank you in advance!
  • 24 Answers
Try reseating the Processor, and checking all the connections on the inside again, also try switching the RAM around such as trying only one RAM stick, one in each slot, if you only have one RAM stick try different compatible RAM.
Posted on Jun 23, 2009
  • HP Master
  • 2,404 Answers
Try using just the ac adapter and see if that works. Make sure the battery is disconnected.
Posted on Jul 12, 2009
Hp pavilion p6654y will not boot
So when you try and turn it on it does nothing, or it tries then dies. What exactly does it do when you push the button to start it up?
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
May 21, 2012 | HEWLETT-PACKARD Pavilion Desktop / AMD...
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
Web cam is not working in hp pavilion dv2401tu on windows xp
Hi
Uninstall your web cam driver and install again, bay your cam driver is occur or corrupt,
May 21, 2011 | HP Pavilion Laptop with AMD Athlon 64 X2...
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
Is there an upgrade CPU available for the HP Pavilion a1410n PC
Here is what your motherboard can handle:
AMD Athlon 64
AMD Sempron
Reference: HP Pavillion a1410n
See Product Information>Product Specifications>Motherboard Specifications
Thanks for using Fixya.
Oct 02, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
I can not start my PC. It does have a green
Sounds like a defective power supply. Improper power coming from the supply will cause a unit to fail boot. Power supplies are about 40 bucks.
Oct 01, 2009 | HP Pavilion Media Center a1330n - AMD...
I have a hp pavilion7935,amd athlon 1.3 ghz,would like to upgrade
You have a wonderful machine and it should not be giving any problem. Are you currently facing any specific problem such that you need to maximize its performance. Well there is Hardware solution for that. You could try to tweak its performance by using the software-- Advanced System Optimizer 2.2 or 2.2 available for download(free) from uTorrent or Limewire....sodeep
Mar 31, 2009 | HP Athlon 4, 1.3 GHz (277517001) Retail...
I have an HP Pavilion Laptop computer Model ze4400 when you push the power on all the lights come on and drives and fan power up then it turns itself off then back on then off over and over with no...
This sounds like a processor or system board failure. Most likely it is the processor. If the unit is still under manufacturer warranty contact them for replacement.
Mar 26, 2009 | HP Pavilion ze4400 Notebook
AMD ultra processor produces more heat what can I do?
Find your laptop model at this website and follow the instructions for cleaning out the CPU fan and heatsink.
Jan 30, 2009 | AMD Athlon 64 4000+, 2.4 GHz...
HP Pavilion ze4400 Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
