Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Protect Light Coming On - BXi 1206D
This is now my second BXi 1206D. I am having a repeat issue with this amp. The amp worked for a month or so, but now, when I turn it on, at low volumes the subs produce a crackle or a gurgle. At high volumes the protect light comes on and the amp shuts itself off. I have checked the wiring of my subs and ensured that I have a good ground and positive. I guess it is something. If I can't figure this out, I pretty much get screwed into shipping it $25 bucks each way to get it fixed under the sellers warranty. Considering that I bought the amp for 170, it is hardly worth $50 dollars to get it repaired, especially with the fear of the same issue recurring... again.
Any ideas? Thanks in advance,
Joe
  • 3 more comments
  • djdurable Jun 24, 2009
    I have a Pioneer AVIC-F700BT head unit with 4 gauge power and ground, and a Rockford Fosgate RCA wire. I tested the amplifier with different subwoofers, and the same problem is there. I also tested it in a different car with different wiring, thinking that it was possibly a bad ground or something along those lines.
    When I actuate the subwoofer by hand, there is no scraping. These subwoofers work on a friends amplifier.
  • djdurable Jun 25, 2009
    What do you mean by checking the amplifiers transistors? I don't have a problem using a DMM, but I honestly don't know what I'm checking for on the transistors. Any simpler way to put it?
  • djdurable Sep 30, 2009
    I have a Pioneer AVIC F700BT deck and 4 gauge power and ground wires. And a Monster shielded RCA cable.
    Thanks
    Thanks
  • Frank Fulton
    Frank Fulton May 11, 2010
    What type of Deck is in the car? and what type of amp kit are you using? Post a comment and I can help you figure this out.
  • 32 Answers
If you actuate the subwoofer by hand, do you hear any scraping sounds?
It's possible the voice-coil is rubbing and tripping the amplifiers protection.
Try the amp on a different sub.
Posted on Jun 24, 2009
  • Intager
    Intager Jun 24, 2009
    The gain on the amp is used to adjust for headunit outputs / level match. (.e.g. 6v / 4v / 2v) Headunits with higher output maintain a higher signal / noise ratio through the signal path, and don't require as much amplifier gain for a given output.
    Simply picking an arbitrary value such as "1" and declaring that optimum or maximum is fruitless.
    In any case, because your still getting sound (however garbled) at low output levels, you may be dealing with a shorted output. If your comfortable use a DMM to check the amplifiers transistors and inspect for blown ground traces as that can induce a DC bias curent into the amplifier stage.
    President:
  • Hifonics Master
  • 1,114 Answers
Well, it looks like your amp has bit the big one. Only advice I can give you is to go easy on your next amp. Check your gain settings on the amp, they should never go beyond 1:00. Anything beyond that is really just gonna cook the amp literally. If you get a new amp, from Hifonics, sell it. They ain't what they use to be. They are now made in China and Tiawan. The printed circuit boards are paper thin and the traces are narrow, in the end they just cook themselves. Take a look at an American Made amp, the difference is in the PC boards! they use millitary spec boards which are 3 to 4 times as thick as a japaneese or chineese amps and the traces are wide and heavy. Basically, they are designed to be abused by us volume junkies and bass heads! It will cost more, but it's well worth it. Best of luck! anytime you've got a question post a comment and I'll help the best I can. I was in custom car audio (IASCA,etc.) for 13 years, Now I play with million dollar home toys. So generally, I can help... Enjoy!!!
  • Frank Fulton
    Frank Fulton Jun 25, 2009
    "1:00" is not an arbitrary # The Pioneer Deck has a 2v preamp the hifonics is .08-8v compatable. "1:00" is roughly 2.5v. Beyond that is "overdrive" If you want to check the transistors, you can, you need to know the value. for arguments sake if you have a resistance of 1. your transistor is wide open and bad. Your average transistor should read between.150 -.180 . The point is, if you want to crack the top of the amp, you will void the mfg warranty alltogether and chances are what you find that's bad will cost you more in parts then it will to ship it out. An average protection circuit is 60-80 in parts, the average transistor is 20-30 and there may be a bad trace as well. Sorry to step on you intager but most people on this site are NOT technicians, you need to explain a problem in a way people can understand, don't dazzle with technical knowledge most don't understand, nor do they need to.
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
I bought a hifonics bxi2006d new and doesnt turn on
you should not have any spark from your ground...you may want check and make sure your ground is properly installed. Try wiring the amp without the cap and see if that works.
Mar 28, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Subwoofer popping noise
i had an amp do that a few years ago i did everything it turned out that it was the cdplayer. then agin myfriend had the problem and it was his altonator he had to get a ground loop isolator they are cheap
Feb 02, 2010 | Hifonics Brutus BXi 1206D Car Audio...
I have a HiFonics 1206D amp and it keeps blowing the main fuse
The 60A fuse is WAY too small!!
The amplifier's Fuse is 80A
You will want the MINIMUM battery fuse @ 80A as well.
Since the current draw at the battery is greater because of the resistance of the wire - an 80A - 100A fuse is recommended.
The purpose of this fuse is to protect your BATTERY if something happens along the length of power wire.
What kind of "shop" are you using?? I would find another one!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Hifonics Brutus BXi 1206D Car Audio...
HiFonics txi4008 not working, partially lighting up
Sounds like your amp has some power supply compents shorted out. Maybe some of the power mosfets are shorted and your only getting a little bit of power. That why only the H is lighting and as far as the green light, it don't take much for it to turn on. If it was major it would go into protect mode but it is'nt. I repair amps for a living and I'm the cheapest you'll find. But if you know about electronics and think you can take a crack at it, check it out. Becareful you could do more damage. Let me know if your interested. skinnman33@gmail.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Jun 06, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
424 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
