Question about Refrigerators
Model 4689589 water resavor
2 Suggested Answers
  • 4 Answers
SOURCE: water keeps coming out of my resavor when it starts to heat up
from what you describe either a bad radiator cap, or a leak in the small hose going to the resovoir,or the line within the resovoir tank is to short or missing,this is whats happening,engine warms up to a point that the cooling system is building pressure,the radiator cap has a set presure release to it you might see the figure direcly on top of the radiator cap, 12-14 lbs rated. it usualy will read something like that, so as that warming engine builds pressure in the cooling system it will eventualy surpass the rating of the radiator cap ,and out it goes and flows in that small line to the overflow resovoir. now when the engine cools back down it now will create a vaccum and should draw that water back from the resovoir to the radiator,but if the hose or hardline that is usualy integral within the resovoir is bad cracked or missing, it would be the same as trying to drink a soda through a straw,but the straw is not inserted below the surface of liquid.or if the straw was cracked, no fluid can be vaccumed up through the straw, the resovoir works on that same principle, it must have a good unobstructed line from radiator to the resovoir,and the line inside the resovoir should go nearly to the bottom of the tank, so the water can be vaccume syphoned out just as drinking a soda with a straw.so check to be sure the line is all good no obstructions,no cracks, and that there is a line that continues within the resovoir tank almost to the bottom as well and it is in good shape as well. last check that radiator cap to make sure the rubber as well the upper gasket portion are still there and not cracked/dryrotted. if all that is in good working order then your radiator should be able to recover the water back.just like sippin a soda through a good straw
Posted on Jul 05, 2012
Blue light flashing in water resavore...Says prime on display
We are helping the student in their research based dissertation you can click on below link and get further details. http://www.researchomatic.com/term-papers.html
Jan 30, 2017 | Coffee Makers & Espresso Machines
1980 colent resavor
Coolant reservoir ? probably close to the radiator ?
Mar 02, 2015 | Cars & Trucks
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
Scooba 390 empty dirty tank
it is trash do to the fact that it is not receiving suction to pull the dirty water to the dirty resavore
Mar 24, 2014 | Eureka Atlantis 2590A Wet/Dry Vacuum
I have a 2003 ford tarus, It intermitatly boils water out the resavor. the temp gauge does not show hot. have changed the thermostste, the resavor cap, flushed it out. what else could it be. it sometimes...
My guess is that your electric fan is not engaging all the time for the cooling system. The electric fan is thermostatically operated by the temperature of the engine coolant. These sensors go bad intermittently and then you have the problem you describe. You need to replace the sensor that operates your electric fan. It should be located somewhere on the radiator tanks probably at the bottom of the radiator. Do not wait to replace the sensor that controls the fan. It will eventually quit working all together and you will be sitting on the side of the road somewhere.
Jan 16, 2011 | 1999 Ford Taurus
I drove in 2 gear insted of drive and now my car is overheating how to fix
open radeator cap not plastic overflow tank. and check water fill radeator if empty and vacune out resavor tank wit wet dry vac to open line to radeator it may be filled with dirt
Oct 23, 2009 | 1997 Mercury Sable
Check engine light - low antifreeze
Chanses are the shop did chk. the coolant in the resavor and probly top it off but did not chk.the radiator witch was low and it drew out of resavor to fill radiator witch is the correct way to fill the radiator, just fill it back up with 50/50 (no water.) I don't think that would make the light come on, as you have a low coolant light for that. For piece of mind have it scaned to find out way the chk.engine light came on.
Apr 01, 2009 | 2004 Kia Sedona
Dash board light indicator
water light check coolent lvl in resavore
Jul 16, 2008 | 1998 Toyota Camry
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
