Question about Briggs & Stratton Garden
How are the springs set on the governor - Briggs & Stratton Garden
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: toro recycler rear bagger linkage set-up to
Hopefully, this will clarify it..
http://small-engines.com/bsgovernors.html
Posted on Sep 15, 2010
Nikota 3500 generator 6 hp engine gasoline wont stay running.will not idle when starting.need spring diagram for engine govenor
Depending on the type of governor the spring arrangement is fairly obvious if you remember the springs are intended to open the throttle and the governor is supposed to close the throttle as the speed rises until the two forces are equal at the governed speed.
The governor and the springs should not interfere with the idle in any way though a generator usually has no idle setting but settles at the governed speed as soon as it is started.
Unless the springs have been disturbed I suggest you concentrate instead on discovering why it won't keep running. It sounds very much like a fuel fault but that shouldn't prevent you servicing the ignition as well as per best practice.
Sep 14, 2017 | HP Electrical Supplies
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
Generator starts fine,runs high then low...high then low...like lobing
check for a broken compensating spring on the governor to carby linkage
Mar 08, 2017 | Electrical Supplies
Governor requires pushing forward to start. Requires two people to start
governors always stop in the full throttle position
when the engine starts the governor action is to move to the idle position against spring tension
the higher tension the higher the rpms
moving the throttle lever increases the spring tension on the governor lever an so the rpms increase
from what you say there is something wrong with the governor/ spring set up
from your photo the system may be reversed and the spring pulls to idle in which case the throttle will decrease the spring tension for higher rpm
which ever way check where the spring is located
Oct 12, 2016 | Cars & Trucks
How to set up the governor on a Kohler K141 petrol engine on Howard rotovator
if it is a petrol engine then the governor arm will hold the carby open when stopped
as the engine starts the governor moves the arm to close the carby off to idle. the speed setting is by a spring attached to the throttle level and a point on the governor lever
Feb 13, 2015 | Cars & Trucks
I need to know where the springs hook on the governor arm on a 445777-0129-E1 briggs 25hp v-twin
on the governor rod there should be a spring that gos around the rod and hooks on both ends of the rod .then theres a spring and its very important that it is the right tension spring,go to a dealer and have him look up the correct spring for that model once you get it the spring will accually make the governor sping the engine wide open till it starts but from the governor arm you should see a holder of some kind or a hole where a spring goes to,thats the best I can do for you without seeing it,the dealer where you get your spring may hae a diagram of it!
Aug 05, 2014 | Briggs & Stratton Garden
Can I change a 10hp generator motor with an automatic throttle to a manual throttle?
Yes, you will be able to control the throttle. Look for a lever that pulls on the governor spring. On some generators, the governor spring attaches to an arm with adjustment screw and locknut or metal tab that bends into position. All that you need do is to pull on the governor spring to increase rpm. The governor spring pulls on the governor arm that is attached to the fly weight governor inside the engine. The fly weight is turned by the cam gear in most cases and the force that it produces is constantly trying to close the throttle. The governor spring provides the counter force to open the throttle. Without the governor, the engine can over rev. Good luck with your project.
Nov 18, 2011 | Briggs & Stratton Electrical Supplies
How do you adjust the idle on the Coleman 6250 Generator
There are many different models of Briggs used however simple methed is to find the governor shaft. Attached to the small shaft will be a lever with the governor spring and linkage that connects to the throttle. One end of the governor spring attaches to the lever and other is attached to either an adjustment screw with locknut or metal tab that can be bent. Increasing the pull of the governor spring on the lever will cause the engine rpm to increase. Bend the tab to allow for greater pull or adjusting the bolt with locknut. Make sure that the engine is not turning much more than 3600 rpm. Use a digital meter with Hz setting to set the output cycles at 60. When set at 60 cycles the engine should be turning about 3600 rpm which is where the engine develops max power.
Nov 09, 2011 | Coleman Powermate Premium Plus 6250W...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Apr 18, 2009 | Briggs & Stratton Garden
Garden Logo
14 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
