Question about HP Photosmart 7520
HP7520 prints blank page
Printer works to check ink status, head cleaned. Just all of a sudden will not print wirelessly. I printed this morning, not this afternoon. I made no changes. Any suggestion. Prior to not printing, it would print a blank page every other page.
agnelkj
  • 210 Answers
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Posted on Mar 17, 2008
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
SOURCE: printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Posted on Sep 09, 2008
jaznet
  • 75 Answers
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Posted on Sep 14, 2008
SOURCE: black ink does not print
i had the same problem. black stopped printing. i always used OFFICIAL HP cardridges, so this problem is not exclusive for refilled cardridges.
This solution (offered here) worked for me:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
I wanted to stress that you should make sure that:
1) you keep the the buttons down untill it shuts off;
2) on restart you get a notification of service;
3) to turn it off again after service before you turn it on for actual use.
Posted on Jan 11, 2009
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
Blank pages
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 25, 2012 | Canon PIXMA iP1000
I have a HP Officejet printer model 6500 E709n (USB connected) and I have just changed the black print cartridge and now the printer only ptints blank ppages. I check of the printer status reveals that...
What about print head?.. perform print head cleaning process through tool box, check any back print out? no remove black/yellow print head clean nozzles manually, try it if not resolved replace print head..browse the link how to clean the print head..http://www.ehow.com/video_4974250_manually-clean-hp-inkjet-cartridge.html
Oct 27, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a hp 6500 officejet wireless printer that i jut put in new ink cartridge and all it does is print blank pages?
This happens as the ink needs some time to saturate the system. Usually one needs to print quite a few pages for the ink to flow through and get to the ink head. A better quicker way is to clean the ink heads with the aid of the software that came with your printer.
Navigate to your windows control panel and double click printers and faxes. Then right click on your HP Officejet 6500 printer and select properties. Then click the Print test page button. Check the manual for cleaning the ink head.
Take care!
damnor01
Aug 30, 2011 | HP Officejet 6500 Wireless All-in-One...
My Kodak ESP 9 printer is printing out blank pages? It sounds like it is printing, but paper comes out the same as it went in, blank. Thank you for your help!
Have you checked the inks, done a head clean.
The status monitor may be faulty and not reporting the correct level of the inks
Sep 01, 2010 | Office Equipment & Supplies
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
My Epson Stylus 880 suddenly started printing blank pages. Can you suggest what would make all print heads stop working at the same time
Hi,the ink are they genuine,try head cleaning and check the nozzle.if's not then the logic board cuold have gone faulty or the print head.
Jul 01, 2009 | Epson Stylus Color 880i InkJet Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Prints Blank Pages...even though ink is full.
problem is likely to be the print head, the ink can dry up inside the print head and block fresh ink from flowing.
you can get print head cleaning solution from ebay, which sometimes works, or else go here to get your replacement print head
www.kodak.com/gb/en/consumer/products/printing-supplies/printhead.../default.htm
the one i have is a clip in clip out part
May 03, 2017 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Photosmart 7520 Logo
32 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
