Question about Bosch Axxis WTA 3500 Dryer
How do I clean the lint cavity area and fan blade on Bosch WTA3500
5 Suggested Answers
SOURCE: How do you clean the lint filter area?
I hate this dryer overall..but, re: the lint: i purchased a long bristol brush from brookstone that is made for these kind of situations. It kind of looks like a long "rifle" cleaning barrel. it helps alittle. just stil it in the dryer and keep turning the handle and try to collect lint as possible. overall..i hate this damn dryer plus it takes forever to dry approx: 1 1/2 hrs to dry one load. my bosch washer model wfmc 6400 series sucks also..it shakes constantly throught out the entire wash..and drain cloggs alost.
Posted on Apr 18, 2009
  • 864 Answers
SOURCE: Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Posted on Nov 11, 2009
  • 615 Answers
SOURCE: After one load, dryer stopped working. lint
With the exhaust clear, you need to be sure that air is actually moving. It could be a bound or bad exhaust blower.
Posted on Mar 28, 2010
Testimonial: "Thanks for you info. How can I check on a bad exhaust motor when I can't get the dryer turned on?"
heatman101
  • 43501 Answers
SOURCE: my bosch wta3500 dryer is not heating to dry the
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Jun 19, 2011
What areas of the Regency wood stove do I clean so that the fan blows stronger?
Many times, the fan blades themselves are the cause of lowered air flow. Think of the blades edges as though they were the cutting edges of a knife. You know a sharp knife cuts its products better than a dull knife....transfer that concept to airflow. A clean blade is sharper and slices through the air much better than a thick edged dirty and dull fan blade. I've seen extreme cases where the edges were 1/8" thick and the area between the blades nearly filled with lint, dust, dog hair and the like.
Service the blower blade first and while removed inspect the inside of the stove in front of the fan with a flashlight and small mirror. That will tell you if additional cleaning is required. If your motor is a cheap little 'shaded pole' motor, it could just be dragging and operating at a lower rpm than designed, delivering less airflow. If so, it may have to be replaced. There are no oil ports on most of these small motors.
Nov 12, 2014 | Home
Bosch WTA3500: is the blower fan to be turning loosely on the axle of the fan motor or is it supposed to be firmly connected?
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch WTA3500 dryer, correct ? Further to this you've stated "is the blower fan to be turning loosely on the axle of the fan motor or is it supposed to be firmly connected?"
...It should certainly be firmly connected and only spin when the motor/drum is in operation.
It can become loose, (check the 13mm nut attaching it to the motor shaft) but if so chances are it has broke from the shaft in my almost 20 yrs. experience. I do have service manuals for these machines, but they come at a cost.
If you want to investigate further and you think/agree the service manual would benefit you, please reply with an email address and I can send it to you, or you can contact me a macmarkus@live.ca
I am presently in the process of setting up my FixYa marketplace account, though I've been here for quite a while...there's been some changes here so I must adapt, lol.
I will watch for your reply.
Regards,
Macmarkus :)
Sep 27, 2011 | Dryers
BOSCH WTE84100 CONDENSOR DRYER .will not start .Power display on and flashing ,all filter are clean, but machine beeps when try to start.
Two Beeps means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Aug 15, 2011 | Bosch Dryers
The dryer heats up but does not dry the clothes completely.
Hi and welcome to FixYa, I am Kelly.
If your dryer cabinet is feeling very wam to the touch and your clothes are not drying properly it is always caused by poor air flow problems.
Here are steps you should to attempt to get it working normally again:
1. Pull out the lint filter
a. Inspect the cavity where the lint filter was (use a flashlight). Make sure there is not lint build-up under the lint filter. Use a folded wire coat hanger and a vacuum with a crevice tool to remove any lin in this area.
b. Wash the lint filter with vinegar and water then soap and water. Fabric sheet particulate builds up on the lint filter. It will appear clean but can still be almost completely blocked.
2. Remove / dis-connect the vent duct from the back of the dryer.
a. Turn on the dryer briefly and check air-flow. The air-flow should push a relaxed hand gently away from the immediate area of the vent duct connection. If you do not have good air-flow here you must inspect the internal ducting of the dryer for restrictions. Use the folded wire hanger and a vacuum to remove any debris from the internal duct vent ducting.
3. Inspect the ducting from the rear of the dryer all the way through and OUTSIDE the home. The vent flapper outside the home is most often one of the primary reasons for poor airflow. Clear the lint from both sides of the metal flapper outside the home.
4. Lastly if after doing all of the above you still have poor air-flow the most likely failure is the blower wheel attached to the motor shaft. Either there is a problem with the fan blades or the center hub has failed allowing the blower wheel to spin on the end of the motor shaft.
A final comment... when you think you have the internal dryer ducting clean.. start over cleaning again for a 2nd cleaning. I cannot tell you how many times I have performed in-home service and the customer said they had done all of the above yet when I clean the same ducting I can fill a 5 gal SHOP-VAC 50% full with the lint they did not remove.
Thanks for choosing FixYa,
Kelly
Apr 11, 2011 | Amana Dryers
Mar 28, 2010 | Bosch WTMC3500UC Gas Dryer
Bosch Nexxt dryer WTMC6300US won't start; seems to be related to lint filter cleaning; washing filter helped once and blowing out lint filter cavity - chronic problem started just when machine out of...
For some reason my display showed the ''key'' icon. I must have switched it to lock somehow...I went through the menu,switched it to off and everything works now! Hope this helps
Aug 11, 2008 | Dryers
Fan doesn't work, blades don't turn
Jump out the switch first that will show which is not working
Dec 21, 2017 | Vornado Standard&Full Size Air Circulator...
Dryer not drying
The is for a WTA3500. Not sure if its the same as the 3510, but it couldn't be too different.
You have to remove the back cover. (Make sure the power is disconnected first, of course.) It's about a dozen screws, no big deal. Once the cover is off, you'll have a view of the heater unit and the blower. The heater unit is a box in the center of the drum with some wires running in and out. On that box is a circular black piece with a red button. Just push that button, and put your cover back on.
You should probably check for any obstructions in the exhaust channels  that might have caused your dryer to over heat while you're at it.
Jan 01, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch in their manual suggests using a vacum with a narrow tip to go into the hole and remove the build up.
Nov 17, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
41 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
