Question about Avanti Freezers
Avanti chest freezer model cf07 not getting cold
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
barkencoa
  • 3463 Answers
SOURCE: red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Posted on Dec 25, 2008
  • 3 Answers
SOURCE: chest freezer not getting cold after moving
IS the compressor running? If so u probably cracked a line and lost the refrigerant charge.
Posted on Feb 27, 2009
  • 15 Answers
SOURCE: chest freezer motor runs but the inside doesn't
Sounds like you have a bad compressor or it has lost the gas charge.
Posted on Aug 05, 2009
Water shorted out freezer power switch, where can I get replacement part. (Texas)
Most electrical jobbers should have a replacement, as long as it fits and the ratings are the same or higher, you can use it. Just take the old one in with you to match it up.
Mar 02, 2015 | Avanti 7.1 cu. ft. / 201 liter Chest...
Won't get cold
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Nov 15, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Pumpishotnotcuttingoff
The thermostat is probably shot. If the fridge is getting too cold and runs all the time. If its an electronic controller, you will need a new board. If its the old rotary knob type, they are a lot cheaper. On the rotary knob type, you can confirm a thermostat fault by disconnecting 1 or the wires to the thermostat and testing with a multimeter. If the circuit stays closed regardless of where the knob is set, that will tell you the thermostat has failed.
Oct 19, 2013 | Avanti CF100 Chest Freezer
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Why dose the freeze only freeze around the top and not the bottom
Hi, Please check your fan for malfunction. Set the thermostat a little bit colder and observe your freezer.
Nov 05, 2010 | Avanti 3.4 cu. ft. / 96 liter Chest...
Freezer not freezing after electric plug went out. Plug was out for a day or two before I noticed it. When I plugged freezer back up, will not get cold.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 17, 2010 | Avanti 3.4 cu. ft. / 96 liter Chest...
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Stop no work
If your freezer is not running at all you will need to change the temp control.If it is running and no freezing then you may have a seal system leak.
May 19, 2009 | Avanti 2.2 cu. ft. / 62 liter Chest...
Freezers Logo
Top Avanti Freezers Experts
Dennis Boxerman
tom wright
tom wright
Steve F
Are you an Avanti Freezer Expert? Answer questions, earn points and help others
