Rolk olsen i have a sound bar R-200 2.4G wireless th problen is the fuse in the subwoofer burned thice in a month Please tell me why???
2 Suggested Answers
johncorde40110
  • 720 Answers
SOURCE: how do i connect my tv to my 300W 2.1 Sound Bar w/Wireless Subwoofer
Best way is to use an optical cable but you need to check that both devices have optical inputs.failing that you will need RCA cables I.e. Red and white capped to produce stereo sounds.usually your smart tv has audio settings in the menu so you will be able to view what connectivity options you have for that particular tv then set them accordingly .
Posted on Jan 20, 2015
Why? Jvc sound bar turning in by itself, no one turned it on, three mornings in a row , turned on radio automatically???
It sounds that you have accidently set up an alarm setting that is set to wake you up in the morning!
Look in the manual and see what it says about timer settings.
Aug 21, 2016 | JVC TH-BA1 Soundbar System with Wireless...
Wireless subwoofer has blinking blue light and not connecting to soundbar. cannot hear subwoofer
Two issues may cause this blinking light. One, no input received from the receiver, or two, the amplifier withing the subwoofer is damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 01, 2013 | LG Lsb316 Sound Bar With Wireless...
CANNOT GET SOUND FROM THE KLIPSCHE SOUND BAR CONNECTED TO AN LG TV
If the sound bar has optical connection I would hook up to tv that way. I had to do that with my lg and sound bar. Hope this helps. Good Luck.
Mar 27, 2013 | Klipsch Power Bar Soundbar with Wireless...
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
What are these parts and where can i get them, subwoofer turns of
your looking at a capacitor (big round thing) and transistor (little black thing)
the y-221 on the capacitor should be a voltage designation, how to identify the transistor, well, i cant see it good enuf to say.
Mar 07, 2009 | JVC TH-M505 System
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Apr 28, 2008 | JVC TH-M505 System
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
42 people viewed this question
 Grubhead
Grubhead
