Question about Springfield Instruments 91066 TriView Indoor Outdoor Thermometer with Hy
How do I correct the year, month and day on my GeoSonic portable weather station
Just replaced the batteries and the daily and 9 day rain gauge flashes continually and does not calculate the total. The date and temperature and correct. The is approximately 3 years old.
Those stations are a royal PIA - not easy to find one that works completely as designed. Either you have not set it up correctly with new batteries or the electronics of unit have gone South.
Oct 05, 2016 | Measuring Tools & Sensors
Changing day/month back to month/day
it can not be changed to what you want it is what it is .
Sep 01, 2016 | Measuring Tools & Sensors
How do I change to fahrenheight from centigrade model 688r06
found this
On the front of the unit is 3 buttons directly under the LCD display. Use the lower left button market "Set" to do all of the settings, time, month, day, year, F & C, etc. There are 2 tiny buttons on the back of the main unit that is + or - and these move thru the changes on each setting. Hold down the "Set" button on the front until you see each item flash, then use the two buttons on the back to get the correct info you want, then push the "Set" button quickly and that sets each category. I hope this has helped you both? I've had mine for several years and lost my manual also but, after using mine for so long, I know how to do all the settings. The manual is not available on the web unfortunately.
Nov 18, 2015 | Measuring Tools & Sensors
How do I set the time and date on my Thermor thermometer
Hold down the mode button for a few seconds > display starts to flash year > use +/- buttons to set year > press mode to present the month/day/time etc, again using +/- buttons
Nov 24, 2014 | Thermor Indoor/Outdoor Wireless Thermo
Set button doesn't work.
I'm unclear, are you saying that if you press the button it lights up or that pressing the button has no effect. Remove battery and adapter and try again, if pressing button does nothing at all the button may be faulty. The only way to prove the button is faulty is to internally short the switch for 5 secs, you will have to dismantle to do that. I suggest you contact:
Apr 29, 2014 | Klockit AcuRite 08580 / 08575 Digital...
Incorrect Date
open shortcut on pc..it will show correct date, time, etc tho unit does not as it hasn't changed days..on the shortcut, click on Update settings then Send to receiver..then punch in button on back of Station..says "pc search"..transmitter on unit will start steady flashing..unit will go black..gradually everything comes back..don't touch until all back..everything will now match the stuff on the shortcut and the day and date will have changed to the correct one..I do this process every day.
Jun 01, 2012 | Sharper Image 5 Day Internet Weather...
Time is correct but date and day is not. How can I set the correct date?
Press the SET button until the month if flashing. Then press the CH button until the correct month is showing. Press SET again so that the day is flashing. Press CH button until correct day is showing. Press SET so that the year is flashing. Press CH button until correct year is showing. Press SET until nothing is flashing. You should be done.
Jan 18, 2011 | La Crosse Technology Technology Weather...
I have had my radio for a while and now just out of the blue the weather band stopped recieving or something, the rest works fine the wx led even lights up just no audio
If there is static noise, then it's probably not the weather board. We have had something like this happen in our area....
The closest weather station to here up and quit transmitting. The transmitter died after years of use. So all of a sudden there was not weather station. It was out for months.
If there is no noise at all, then there is probably something wrong with the weather board. I don't mess too much with weather boards my self. You could look at the weather channel selection knob and look and make sure all the wires are connected, also the switch to turn on weather.
Nov 10, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
This question reffers to my private weather station software. Why isn't my data appearing on the forecast page?
It takes about 1 day for our database to update all of our web servers and place your station on your local forecast page. Also, if there is no current data from your station, we will remove it automatically from the list until we get the next update. Also, make sure you have correctly entered your ID in all capitals. The password is case sensitive.
Aug 12, 2010 | Timex Measuring Tools & Sensors
I'm in MI. The weather channel audio has been bad for a few months now. The sound and speech are broken. Why hasn't this been fixed? Certainly someone must monitor the channel.
it depends on where in MI you are in. I have the same problem and i am near the metro detroit area. some areas in michigan are bad for radio stations. go to the weather channel website and let them know of the problem that you have. they might have a solution.
Feb 08, 2010 | Weather Channel COMPACT TV/LANTERN/ EA...
Springfield Instruments 91066 TriView Indoor Outdoor Thermometer with Hy Logo
208 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
