Question about Stealth Cam STC-Z3IRTL Core Triad-Equipped 40 IR 3.0 MP Hunting / Scouting Camera
Reset passcode on stealth cam
Cant access the setting must reset pass code
I need to lock my xbox
You can use a Family Setting Pass Code to restrict access
http://www.xbox.com/en-US/support/family...
You can also set Family Timer settings to restrict time
When they type in the wrong pass code, they can access the reset pass code question. So just make sure they can't guess the answer to your pass code question or you might find yourself locked out.
Source(s): http://www.xbox.com/
Dec 11, 2013 | Microsoft Xbox 360 Console
Forgot password to XBOX account and cant reset password what else can I do to reset password
ou can use a pass code - a button sequence on your controller - to control access to your Xbox Live account. Once the pass code is set, anyone who wants to use your profile must enter the pass code before signing into Xbox Live.
  1. Go to Settings, select Account and then select Account Security.
  2. Select Pass Code.
  3. On your controller, enter a four-button code by pressing X, Y, the triggers, the bumpers and the directional pad.
  4. Enter your code again to confirm it.
Oct 12, 2013 | Microsoft Xbox 360 HardDrive 250GB Slim...
I bought my xbox 360 from a buddy a few years back and my brother as of recent has been an *** and i want to set a passcode of the 360 itself so he cant use the xbox live without the code. and there...
From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
Enter an incorrect pass code.
You will be told that your pass code is incorrect. Select Reset pass code.
You will then be shown your pass-code question and asked to answer it.
Hope that helps, best of luck.
May 24, 2011 | Microsoft Xbox 360 Console
I can't keep a pass word i have had 4 tonight and still cant access my account
Password from ISP or router? IF you dont know pass from ISP, you can check from your ISP.
But if you forget PASS for router, then i sugget that you try setting back your router. Reset it back and setting it again
May 24, 2011 | Computers & Internet
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jan 24, 2011 | Microsoft Xbox 360 Console
Have this router. Was using default unsecured on my my daughters and my wifes computers. Mine is windows xp daughters and wifes are windows 7. christmas day we were all on line. I secured my computer and...
You can reset everything by pressing the reset button found in a recess small hole next to the power connecter. Use a straighten paper clip or tooth pick in the hole and gently press the switch for about ten seconds. this will set everything to the default stage. Then you can access the router the normal way.
Dec 27, 2010 | D-Link AirPlus DI-524 Wireless Router
A couple of years ago i made my xbox live account and accidentally set the family settings to high now that im using my xbox agian i cant really do anything on live since i dont remember my password or...
spacer.gifReset a Forgotten Pass Code
Oct 16, 2010 | Video Game Consoles & Games
How can i unlock my message,i cant gain access to my messages
Usually each service provider has a procedure to access messages. If it is the first time, usually you will need to set up your phone/messages with a pass code. Otherwise, if you forgot your pass code you will need to reset it by calling customer support. Some service providers allow to do this by accessing your account online.
I hope this helps!
May 21, 2010 | Sony Ericsson P1i
Xbox 360 password recovery
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-555-741. They will resolve the issue for you
Hope that helps
Scanss2k
Aug 19, 2008 | Microsoft Xbox 360 Console
Stealth Cam STC-Z3IRTL Core Triad-Equipped 40 IR 3.0 MP Hunting / Scouting Camera Logo
259 people viewed this question
Top Stealth Cam Video Cameras Experts
Are you a Stealth Cam Video Camera Expert? Answer questions, earn points and help others
