Question about Dell Alienware M11x Gaming Laptop Computer (Intel CORE I5 520UM 160GB/3GB) (DKCWNN32) PC Desktop
Cd I have an alienware and a cd is just spinning. There is no tray, it's just a slot. The eject feature on my PC isn't responding. Any ideas?
    Sergeant:
  • Dell Expert
  • 464 Answers
Hit FN+F6 and it ejects
Posted on Sep 13, 2014
benwabnick
  • 2404 Answers
SOURCE: CD STUCK
Take a paper clip and on the front of the drive there should be a small hole. Put the paper clip in the hole and push it in there and the door should come out and you can take the cd out.
Posted on Aug 03, 2009
  • 59 Answers
SOURCE: i cannot get ehe cd drive on my dell desktop 4500
CD bezel front face is pushing on the eject button. Mine does it too!
Posted on Nov 21, 2009
SOURCE: I have a CD stuck in the drive on my Dell
These responses are usually correct, but the M6400 does not have a hole. I have encountered this issue and have found the only way is to reboot the computer and ejecting during POST or shortly after. I think that there is some process that has it locked, probably some Dell bundled software.
Posted on Apr 13, 2010
nicklemarr
  • 296 Answers
SOURCE: my dell studio one wont
Try to maunal eject is from "My Computer". Right click on the drive and click eject. If that doesn't work, then you need to replace the drive.
Posted on Mar 21, 2011
  • 998 Answers
SOURCE: CD or DVD does not stay in slot. Computer ejects
The Dell™ XPS One™ A2010 system features an enhanced one-time boot menu that is easily accessible by pressing at the Dell™ logo during POST. The options in the boot menu are:
  • SATA:3M-WDC WD2500AAJS-75RYA0
  • CD.DVD:3S-TEAC DVD+/-RW DVW28
  • Network:IBA GE Slot 00C8 v1250
  • Dell Diagnostic Partition
Try to boot from a boot-able CD such as the Dell Resource CD. If it still ejects the CD then your CD/DVD drive needs to be replaced.
Posted on Jul 27, 2011
SD Card and disc stuck in CD slot of Alienware M14x?
try taking a small piece of wire and bending a small hook into one end slide it in on TOP of the stuck disc and hooking the center hole of the disc, (you don't want to get the wire under the disc because you could damage the disc reading hardware) also once you have the disk hooked you may have to use the tweezers to gently hold the front of the disc up to align with the slot as your pulling it out. you should feel a little resistance but don't try to force the disc out too hard.
Mar 23, 2015 | Dell Alienware M14x Notebook
How do you eject a cd from an alienware 14
you should be able to see a very small pin hole on the cd rom itself.
Get a paper clip and unfold it, insert the longest end into the hole until it hits something and give it a push.
You can also go to the cd\dvd rom and right click- eject
Jul 22, 2014 | Alienware PC Systems Alienware M14X 140...
How to eject cd, no tray, just a slot
You can eject it by going to computer. Then look for the cd drive letter. Right click on it and look for eject.
David
Mar 26, 2013 | Samsung NC10-14G Notebook
How to eject CD
If the eject button on the CD player does not respond then straighten a paper clip and insert it into the tiny hole on the CD tray. Gently push the paper clip in and the tray will pop out, you can then pull the tray out to the fully opened position to remove the CD disc.
Mar 03, 2012 | Dell Computers & Internet
How to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Dec 28, 2011 | Dell Computers & Internet
Stuck dvd
There is a small hole close to the CD/DVD tray, stick a paper clip in it to manually eject the disc.
Nov 24, 2011 | Alienware PC Systems Computers & Internet
My computer wont read any cd's or dvds... I open the tray, everything works it has power to it and I can hear the cd spin inside as it trys to load then it stops and nothing happens on screen. If I put the...
It's a common problem if the cd\dvd rom is very used. Try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 13, 2010 | Alienware PC Systems Alienware Aurora High...
CD Drive
Studio systems does not have any tray because it uses a slot. Theres no mechanical eject button. You may eject it using the Fn+F10 key on your keyboard.
Jun 14, 2009 | Dell Studio 1737 Laptop
Help
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
Dell Alienware M11x Gaming Laptop Computer (Intel CORE I5 520UM 160GB/3GB) (DKCWNN32) PC Desktop Logo
80 people viewed this question
Alun Cox
