Question about LG Computers & Internet
How do you take a screenshot on a lg computer monitor ?
Laptop[
How can I take a screenshot on my laptop computer
What laptop?
What Operating System?
In windowss you can use the "Print Screen" function by pressing the "PrtScn" key on an extended keyboard. If you hold the "Alt"-key while pressing the PrtScn-key, it takes a snapshot of the currently active window.
Then you have to open a paint or Word document. Now you can paste the screenshot.
If you use Windows 7, click the Start button and type "Snipping Tool". This will start the built-in screenshot software.
Oct 25, 2014 | Computers & Internet
Tip
Take screenshot of Android phone.
You can take screenshot of android phones when conencted to a computer.<br /><br /><br />To take a screenshot you need to download the Android SDK for your machine. It includes a tool called ddms which is the dalvic debug monitor. Dalvic is the Java runtime powering all the apps on your android phone.<br /><br />Connect the phone to your machine, run ddms from the terminal and go to Device &gt; Screen Capture (or Ctrl-S) for taking a screenshot.<br />
on Feb 06, 2011 | Google Android
Printscreen
How to Take Screenshot on Thinkpad eHow
Screenshot of Entire Screen
  • 1 Visit the website or computer page of which you want to take a screenshot.
  • 2 Press the "Print Screen" button. It may be labeled "Prt Sc," "PRTSC" or "PRTSCN."
  • 3 Click the Windows orb. Type "Paint" in the white search bar and click on the "Paint" result under "Programs" to open Paint.
  • 4 Click on the button labeled "Paste" in the top left corner of the screen. Click the blue "Paint" button in the top left corner of the screen, and click "Save." Find a location on the computer to save the screenshot and click "Save."
  • Screenshot of Certain Screen
    • 1 Open the screen that you want to take a screenshot of.
    • 2 Hold "Alt" and push the "Print Screen" button.
    • 3 Click the Windows orb. Type "Paint" into the search bar and click "Paint" under "Programs."
    • 4 Click the "Paste" button to paste the screenshot. Click the blue "Paint" button and click "Save." Select a folder in the following menu that appears to store the image and click "Save."
    Read more : http://www.ehow.com/how_8517673_screenshot-thinkpad.html
    Mar 12, 2014 | Lenovo ThinkPad Edge E531 Laptop
    Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the right...
    Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
    May 10, 2012 | LG 22" FLATRON LCD Monitor
    I cannot see a button or anything to turn on my monitor.
    It looks like you didn't notice the buttons, there should be three buttons on the right pane of the monitor (vertical and when you look at the monitor, they are on the right-hand side), or at the right side panel, which isn't visible from the front, you have to look at them from the right side. Refer the screenshots below (buttons are highlighted):
    Front
    Right Panel
    Hope this helps, let me know if you need further help.
    Good Luck.
    Thanks for using FixYa.
    Jun 22, 2011 | LG Flatron L1718S LCD Monitor
    I have an LT Series Gateway Netbook. I am trying to connect to a Sony VPL-AW15. I am using a Sony STR-K7000 A/V receiver. The projector is giving the error message "Frequency out of range". I have...
    HEy try changing the refresh rate
    1. Right click on a empty space on the desktop and click on Screen Resolution. (See screenshot below)
    2. Select the monitor Display you want to change the screen refresh rate for. (See screenshot below step 3)
    NOTE: You will only be able to select a different display if you have more than one monitor connected.
    3. Click on the Advanced settings link. (See screenshot below)
    4. To Change Only the Screen Refresh Rate -
    A) Click on the Monitor tab. (See screenshot below step 4C)
    B) Select an available Screen refesh rate from the drop down menu.
    WARNING: It is recommended to leave the Hide modes that this monitor cannot display box checked to prevent possible damage to your monitor.
    C) Click on OK. 143d1229784117t-screen-refresh-rate-display-settings-monitor_settings.jpg
    D) Go to step 6.
    5. To Select from a List of All Display Modes -
    A) Click on the Adapter tab, and on the List All Modes button. (See screenshot below) 7331d1238960189t-screen-refresh-rate-display-settings-adapter1.jpg
    B) Select the display mode with the screen resolution, color depth, and screen refresh rate that you want to use, and click on OK. (See screenshot below)
    NOTE: It is recommended to use a native screen resolution with a True Color (32-bit) color depth. 7332d1238960189t-screen-refresh-rate-display-settings-adapter2.jpg
    C) Click on OK. (See screenshot below step 5A)
    6. Click on Yes to confirm the screen refresh rate change. (See screenshot below)
    7. Click on OK. (See screenshot below step 3)
    Apr 28, 2010 | Lenovo IdeaPad S10e Netbook
    Hi - Received a LG monitor, W53 Series as a gift.
    in your laptop there is button press f5 or f6 to get dipaly on lg monitor or you can right click and go to display properties and set the dispaly.
    Sep 08, 2009 | Computers & Internet
    Added a ge force 8400 gs pci grfx card to hp a6120n monitor
    Alright, let's give this a shot. Your system can handle it as the card only needs 71W of power.
    Right-click your desktop and go to properties.
    Screenshot.
    Afterward select the tab at the top reading, "Settings."
    Screenshot.
    Now select your new video card in the, "Display" region and choose the device to be your, "Primary Monitor."
    Screenshot.
    Afterward try plugging the monitor into your new graphics card. It should work just fine.
    Feb 03, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
    Two monitors, one computer....
    Here is a link that will walk ya thru setting it up..http://freepctech.com/pc/001/guide_dual_monitors.shtml Good luck.
    Mar 18, 2007 | LG L1530S 15" LCD Monitor
    Computers & Internet Logo
    35 people viewed this question
    Top LG Computers & Internet Experts
    Michael Vincent Cruz
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
