Question about Samsung RF266AEPN
Is GE refregerator part # ap4363643 compatible with model PFSS0MFZJSS?
My GE refregerator make a very big noise very time it shuts off. please help
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Aug 18, 2010 | GE Refrigerators
I need electric diagram for ge refregerator pds22sbralss i can not find it.thanks
Will you settle for a Service Manual that covers most profile and Artica refrigerators? I believe it will be difficult to get your exact model and the difference is small changes. I just don't want to send you something I know will work and get a bad rate. Or explain what part of diagram are you looking for. Sea Breeze
Jan 20, 2010 | GE Refrigerators
The freezer section of our ge refregerator keeps making a loud buzzing noise and causing our food to frost. I have already lowered the temp.; however, it doesn't seem to help.
This would indicate moisture is getting into the freezer and not getting out.
Run a manual test of the defrost cycle.
Aug 16, 2009 | GE Freezers
GE refregerator
this is a drain issue..check to see if you have a plastic drain trap going into back of refrig . its located about middle of rear of box. this is where your water drains out of and down to drain pan. this gets filled with food particles and such and stops up flow of water..remove by twisting and pulling out slightly..clean out and re=install...if you do not have this..go and remove freezer back wall..you will need to open drain and clean out trough under evaporator..use hot water and continue until water flows down into the pan..
Jul 11, 2009 | GE Refrigerators
GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
May 20, 2009 | GE Refrigerators
Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Jan 24, 2009 | GE GBS18HBM Bottom Freezer Refrigerator
Re charging the old refregerator
Check the compressor see if there is a fitting with the screw and inside the screw has a pin. If the compressor has this fitting, that for the Freon R-22 charge use. good luck!
Jul 26, 2008 | Heating & Cooling
CAnnot set REfregerator teperature going to 65 all the time
you have a bad main control board -- $300 plus to fix it. the board is on the back of the unit. if you can get the part locally, it usually comes with instructions -- good luck.
Dec 13, 2007 | GE PSS26SHRSS Side by Side Refrigerator
Samsung RF266AEPN Logo
69 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
