Question about Garden
Ive got a murry lawnmower,it starts with some trouble. Once it is on it is powerless
2 Suggested Answers
  • 10865 Answers
SOURCE: lawnmower has trouble starting, but runs
Hello. Did you replace the air filter? If not check it and replace it if it is dirty. Finally get a carbeurator cleaner such as seafoam which you add to the fuel at the rate of one ounce per gallon. This will get the inside of your carbeurator cleaned up. Do these things and you should be back in business.
Posted on Jun 20, 2009
MY MURRY M2510 WEEDEATER PULL CORD IS CEASED UP. I CAN'T PULL IT TO START THE MOTOR AND IT WAS WORKING FINE.
that is how things normally quit . all at once for no apparent reason .do not know if you have a local repair shop to assist you .
Oct 12, 2017 | Weedeater Garden
Replacing a primer bulb on a 22' murry 5 hp lawnmower
Pick up a replacement kit at a auto parts or hardware store, they are normally held on by two screws
May 07, 2015 | Garden
Having trouble starting the lawnmower. When I turned it on its side to check the blade and turned it back it started. How can I solve this
Sounds like a odd solution.
After several years of working on small engines, I can tell you that 4 out of 5 times that a lawnmower doesn't start, it is a fuel delivery problem. Other issues could be a weak spark, low compression, or a clogged air filter.
If you have confirmed that the lawnmower has spark, checked the air filter, and can feel a good bit of compression, your problem likely lies in the carb.
The only way to solve this issue is to take it apart and clean it. Some models require that you replace components such as a fuel pump diaphragm. These are popular with Briggs engines.
The process is fairly detailed but you can use this guide to cleaning a lawnmower carb for detailed assistance. Good luck.
May 24, 2013 | Garden
Hydrostatic transmission Fluid alternatives
no it will not work use hydra or hydra ultra
Sep 15, 2009 | THQ The Lawnmower Man
Need a wiring diagram for a Murry Rider, Model # 30575X8A.
Go to this web sight and enter your model number of your Murray.
http://www.murray.com/manuals/
Jul 17, 2009 | Mtd Garden
Lawnmower has trouble starting, but runs
Jun 20, 2009 | Garden
Murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Jan 17, 2009 | Garden
Having Trouble Starting up G37
For about 2 wks ive had some trouble starting my Infiniti G37. every once and a while when i start up my truck it had some trouble but it would eventually start. it would only take me about once or twice to start it. i thought it was a cold engine problem. but now the ****** wont even start at all. all i can hear is the clicking noise. i know its not the battery cause it shows it is pretty well charged on the instrument panel window when my truck is actually running. so not being much of a gearhead can anyone help me out. is it something i can fix without getting any parts? or am i doomed to being a whole new starter. btw it started today with the help of jumper cables. but like i said i dont think its the battery but i can be wrong.
May 14, 2008 | 2008 Infiniti G37
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
