Question about Dishwashers
I have a whirlpool et8mtmxkq0 and it has quit running. Is there a reset button!
  • yadayada
    yadayada May 17, 2014
    Hi Tommy Bell, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
How can I get my dryer running?
You need a new machine control board
Oct 02, 2016 | Whirlpool Dryers
Why won't my washer start?
with the machine switched on push and hold any two buttons for at least 30 sec.the machine will reset.adrian.
Jul 14, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
My washing machine stopped running. It may have been too full but i heard some clicks and then it quit. Is there some sort of reset button?
you can try to unplug it for 15-20 mins to let it reset itself hope that works (appliancerepairplanet.vstore.ca )
Dec 09, 2010 | Whirlpool Washing Machines
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher quits running and clean lite keeps flashing.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Aqua glass jetted tub quit working
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
Feb 13, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Whirlpool dishwasher Quiet Partner II DU1100XTPQ7 Mine runs but will not drain. Took it apart and cleaned out as much as I could around the trap, but could not figure out how to pull out the sump and seal....
i have a simular problem but everything quit working even the lights. Is there a reset button. Ive checked to make sure there is power supplied to the dishwaher. Please help.
Jan 11, 2010 | Dishwashers
Whirlpool Performa
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Mar 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
Owen Barnes
