Question about LG Dehumidifier LD650EAL
Stop working ld650eal code 67 - LG Dehumidifier LD650EAL
Ld650eal dehumidifier not running
Could be low on freon or humidestat is bad..
Sep 16, 2014 | LG Dehumidifier LD650EAL
Code: CH 67
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
Oct 20, 2013 | Maytag M7DH45B2A Dehumidifier
Bucket full light is on, but there is no water in the bucket
I had the same problem. For me the fix was to take all the covers off, remove the bucket switch, clean the contacts on the switch, and i poured alcohol all over the switch and repeatedly pressed on the actuator . I dried it all off, put everything back and it worked again like a charm.
Aug 23, 2012 | LG Dehumidifier LD650EAL
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
I have a lg dehumidifier ld650eal. it has a code of ch 01. the bucket full light flashes. if it is off and i turn it on it will start for a second or two and shut down and display the ch 01 code.bought 13...
Unplug power cable,then take of front panel (2 screws).Then on left side on pipe se cliped sensor on pipe ,unclip then put in hot wather for 5 sec. Then put all back together and plug cable power and turn ON.That works on my Dehumidifier LG LD650EAL.
Jun 14, 2011 | LG LD65EL Dehumidifier
I bought an LG dehumidifier last summer and it worked fine until about 2 months ago. Then there was this constant clicking noice. It seemed like it was electrical with the switch or something. It was...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 22, 2011 | LG LHD45EL Dehumidifier
LG Dehumidifier LD650EAL Logo
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
