Question about Vehicle Parts & Accessories
Radio stays key off door open - Vehicle Parts & Accessories
    Master:
  • 710 Answers
The radio has been wired to a constant power source. It will need to be rewired to a keyed pwer source.
Posted on Sep 07, 2014
MY RADIO STAYS ON WHEN I REMOVE THE KEY and close the door
radio stays on after removing key from ignition - Car Talk
community.cartalk.com/.../radio-stays-on-after-removing-key-from-ignit...
Mar 4, 2012 - this just started today and when i turned off my car and removed the keyfrom the ignition, the radio stayed on.
04 F150 - Radio stays on after key removed & door open ...
www.f150online.com/.../323659-04-f150-radio-stays-after-key-removed...
Mar 2, 2008 - You know how you can take the key out of the ignition (after turning off), and radio continues until you open the door? Well, yesterday I opened ... More results from www.f150online.com
Oct 22, 2015 | Chevrolet Astro Cars & Trucks
2005 chevy express 3500 door light and radio stay on when you turn van off take the key out and open the door. how to fix
This Van has a system in it called delayed exit, this means the radio and other accessories stay on for a time as long as none of the doors are opened, when the door is opened the module senses that switch in the door is activated and shuts everything off. The easy way to test this is open the passenger door, if all shuts off you found the problem, the driver door switch is defective. the switch is attached to the door lock inside the door.
Oct 04, 2012 | 2006 Chevrolet Express
04 expedition radio won't turn off after I take
Does it turn off when you open the driver side door? If so, that's normal. My car also keeps the radio on when the key is taken out of the ignition until I open the driver side door. If the driver side door is not opened then the radio will only stay on for 8 or 10 minutes though. If it's not turning off ever, even when you open the door, then I don't know what's wrong with it.
Cheers!
May 02, 2012 | Pioneer Car Audio & Video
When engine turned off and keys removed, the radio and interior console remain on. They don't turn off once the door is opened, and the doors will not lock unless you manually lock with the key. Went to...
Sounds like you have a short to power. there are several wires that connect to your radio and console . one is the ignition wire that kills power to the radio and console when the key turns off. What has probably happened is that wire has found a constant power source from another wire and it constantly stays on. finding this short is very difficult because it is under the dash so you might want to take it to a professional. Also if the van has the feature where the radio doesnt cut off until you open the doors, then your short may be somewhere in the sensors on the doors.
Jan 05, 2011 | 1999 Chevrolet Venture
Audio system goes off when I open car door
If your key is off, this is normal operation for most cars. The accessory wire to the radio will stay hot with the key off for some time (maybe an hour), unless you open the door. If you want it to stay on, leave key in accessory position.
Sep 07, 2010 | JVC Car Audio & Video
My 2006 Ford Fusion's radio won't turn off. Everytime I take the keys out and open the door the radio doesn't cut off!! Why!!!
U have a defective door ajar switch most likely, if this switch remains closed then the delayed exit feature stays on, this means the radio will stay on because the delayed exit module didn't sense the door was opened, try opening the passenger door to confirm this problem, any door should turn off the radio
Mar 11, 2010 | 2006 Ford Fusion
With the key off and the door open, the radio stays on.
The key switch is probably worn with two affects it may be you can remove the key before it is properly turned off or is worn internilay.
Aug 06, 2009 | 1986 Cadillac Seville
Radio won't turn off.
The radio should still shut off after 20 minutes even if the door is not opened. If it stays on longer than this there is still a problem..
Jan 25, 2009 | 2003 Oldsmobile Alero
Radio in 05 Malibu Maxx LS
The reason the radio is staying on is the retained accessory power not shutting down when the driver's door is opened. You can verify this by opening the door with the key on, if the door ajar light on the instrument panel does not light up the switch in the door latch is defective. You will need to replace the door latch.
Aug 20, 2008 | 2005 Chevrolet Malibu Maxx
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
