Question about Philips REM110 Remote Control
Tevion tv t2731u code direcTV
No volume on direcTV remote.When using tevion tv t2731u
2 Suggested Answers
SOURCE: Need a code to program a philips tv into a directv rc64 remote
I NEED THE THREE DIGET CODE FOR MBR3447 REMOTE
Posted on Mar 20, 2009
My Directv remote, RC66x, will not let me enter any codes for my new Proscan 3273A tv...Why?
Your new Proscan TV may use different codes not available from your remote.
Jun 07, 2016 | Directv Televison & Video
Tevion LCD3210ID remote codes - Please Help
i cant get anything on my tevion television/dvd
May 22, 2009 | Televison & Video
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
Studio Series 54
http://www.directv.com/learn/pdf/Remote_Controls/universal_remote_user_guide_new.pdf
Find the 5 digit codes for your TV
Switch/Slide your remote control mode to TV mode.
Press Mute and Select button together and hold it until TV mode flashes twice.
Using the number keys, enter 5 digit code for your tv brand.
Press Off button. Try every single code until your tv turns off.
Some common brands and their codes:
If your TV is
- Sony, code is 10000
- Toshiba, code is 12006 (most models and make sure your remote control is version RC64)
- panasonic 10250 most models
- Samsung 10702 most models
- sharp 10093 most models
Oct 18, 2008 | Televison & Video
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Tevion TV with no compatible universal remotes
Check out eBay to see if someone has a remote for sale. This is not a name brand TV set, and therefore there is probably no support for service and parts.
If you decide to change TV sets, stay with the big name brands, and check them out for after sales support and service.
Jerry G.
Apr 12, 2008 | RCA L37WD12 37 in. LCD HDTV
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    Philips REM110 Remote Control Logo
    14 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
