Question about Raypak SpaPak Model ELS R-552-2 Electric Spa Heater - 5.5 kW 240/60
Why my raypak 552-2 shuts off? - Raypak SpaPak Model ELS R-552-2 Electric Spa Heater - 5.5 kW 240/60
My raypak spa heater does not cut off . once it is on it heats spa to 112 and when adjusting the light does not come on and no longer makes a click like the thermostat is not shutting the unit off.
This is a thermostat or high limit switch issue - I had the same problem with my hot tub. It is a very common component to go bad. Have a serviceman look at it - but if you are savvy enough you could do it yourself.
May 02, 2017 | Raypak Pool & Spa
What could cause A Raypak 336a heater brand new i get a (pv output fault )will run for 10 min then shut off
if wired 120 volt see wiring on inside of front panel also check gas pressure sounds like safety mode
Jun 29, 2014 | Raypak Pool & Spa
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak heater shakes and makes noise and shuts off
check for the pump if is at thje high speed if not check for thermostat. clean basket clean filter a must
Aug 31, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Raypak SpaPak Model ELS R-552-2 Electric Spa Heater - 5.5 kW 240/60 Logo
27 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
