Car Audio & Video Logo
Posted on Jun 23, 2009
How to remove the door speakers in a 99 3000 gt.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
2036
Points
12
You have to remove the door panels. Most are some screws in the door and then an upward motion on the panel. If you are putting in aftermarket speakers you might have to splice on different adapters for the speakers. Let me know if you have any more questions
Canon lbp2900 red light
>> Check the paper jam
>> Remove print cartridge
>> Clean the sorroundings
>> Check the printer door and also check the door sensor (which is located at left side of print door.
>> It may help.
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
1helpful
My w595 phone speaker does not work , i can`t talk with other.
Play a asong to check whether the problem is with the speaker or the phone. If you hear the song when played through walkman then , Check whether the volume of speaker is low. for this make a call. when you see the call in progress on your display press the rocker keys on the side of your phone to adjust the volume of the speaker while making a call.
You can chage the volume by the roker keys provided with the symbol "+" and"-" Sony walkman series phones stores two different levels of volume for the call and for the Multimedia.
If the volume is full and still the sound wont come then follow these steps.
If you have the proper tools >>remove the battery. >>open the back cover of your phone >>open the front panel of your phone >>carefully unscrew all the screws visble >>now take out each part with care.(samo needs extra care while pulling out from the base board.) make sure you dont break the borad. now you gain access to the speaker near the speaker port. use an eraser to rub and clean the terminal s of the speaker as well as the mother board of the phone.(Dont rub too hard or else you will damage the phone) >>now put everything back and switch on your phone. You should be able to hear the sound.
if you still dont hear the sound replace the small speaker( you already know how to remove it as you have opened the case once) it wont cost more than 2 or 3 dollars.
if dont have the proper tools >>Go to the nearest dealer/shop and hand over the phone to them. Let them do their job. They will replace the speaker immediately. wont take long
1helpful
Front driver door has no power, I have checked the fuses but no controls will work
This is a manufactures bulletin
SUBJECT:
Inoperative Right Front Door Switches OVERVIEW:
This bulletin involves replacing the right door interior handle. The loss of ALL functions may occur when attempting to control them from any of the switches located on the right door due to electrostatic discharge through the right door interior handle. The right door interior handle must be replaced to protect the switch module from static electricity. The new handle is more resistant to electrostatic discharge. MODELS:
2004 - 2008 (CS) Pacifica SYMPTOM/CONDITION:
The vehicle operator may experience a permanent loss in ability to actuate ALL of the following functions from the right door switches: ^ Power door locks. ^ Right power mirror. ^ Right power seat adjustments. ^ Right power window control. ^ Right heated mirrors. ^ Memory functions associated with the listed systems on right side (if applicable). ^ Loss of communication with the right door switch module to Scan Tool: DIAGNOSIS:
Perform a "Hard Reset of the right door switch module. This may be accomplished by removing all power (including memory keep alive power) from the right door switch module by unplugging the module power connector. Alternatively, vehicle power may be interrupted by removing the negative battery terminal when the ignition switch is in the OFF position. If after performing the hard reset functions of the right door switches return perform the Repair Procedure.
PARTS REQUIRED:
REPAIR PROCEDURE:
1. Disconnect the negative battery cable. 2. Remove the right door trim paneldak408_80.gif
3. Remove the door tweeter speaker. Refer to the service information in TechCONNECT. Refer to 8 - Electrical > Audio > Speaker > Removal (Fig 1). 4. Remove the power seat switch. Refer to the service information in TechCONNECT. Refer to 8 - Electrical > Power Seats > right Seat Switch > Removal. 5. Replace the right door interior handle, p/n 05170261AA, as described on Mopar Instruction Sheet K6855628 included in the handle kit. 6. Install the power seat switch. 7. Install the door tweeter speaker. 8. Install the right door trim panel. 9. Connect the negative battery cable.
1helpful
Stereo wire color > front doors speakers
Try this link.
http://www.the12volt.com/installbay/stereodetail/1412.html
2answers
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
Changing front door speakers in 1990 Mazda RX-7
The size of speaker that will go into that vehicle is a 6 1/2". You will need to take off the door panel in order to remove speakers. Once door panel is removed, locate screws holding speakers and remove and reinstall new speakers.
14helpful
2answers
1999 Ford F150 supercab - back driver door won't open
You will have to open it from the inside-Yes, I have done it and it takes about 15 min. or so.-I have also posted about 40 images, after I opened the door-In an effort to contribute a little to all the lost souls with the Curse of the F150 3rd Door issue. Hope this helps-BTW I just did this on 12/04/2011-found my particular issue-I will need a new cable, so I'll have to go to the dealer tomorrow and buy one. Also included images of the tools needed-Good Luck!
Link to the images are here>>>http://s289.photobucket.com/albums/ll220/techdispatch/F150%203rd%20door%20curse/?start=all
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
