Question about JVC KD-G230 CD Player
How do I know what wires go where from my new CD player to my old wires or explore Ikeanani
My problem is I just bought a Ford Explorer and had no radio the wires were cut I have a new CD player to install it but I don't know what Wire is what can you help
5 Suggested Answers
  • 7 Answers
SOURCE: installing a new car radio
if you have a wiring harness al the wires are color coded to match the after market radios colors. the yellow constant wire goes to 12 volt or battery wire. the accessory wire would be the red wire that is the switched 12 volts. the remote is for the factory amp or an aftermarket amp which turns on and off it would be the blue with white wire.
Posted on May 28, 2008
reynosaelect
  • 165 Answers
SOURCE: Installing a cd deck into car
BUY THE HARNESS ON WALM MART IS GOING TO BE MORE EASY IS ON THE CAR ACCESORIES DEPARTMENT
Posted on Mar 19, 2009
SOURCE: wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Posted on Nov 11, 2010
Xeuvious
  • 100 Answers
SOURCE: where do you connect
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Posted on Mar 02, 2011
Will a 2002 ford explorer stereo mount in a 1996 ford explorer
offcourse it will.You might have to change the connectorplugs these are changed all the time but you can just connect the wires one by one
Mar 16, 2014 | 1996 Ford Explorer
96 ford explorer removed factory radio to put in new CD player. Now I cant get it to work had to cut factory wires n not sure how to rewire to new CD player plus it has messed my wipers up too. Please...
A 4.0-liter V6 engine with a 4-speed automatic transmission is standard on all 12 models of the 1996 Ford Explorer. --------------------------------------------------------------------------
Car Key Programmer
Nov 28, 2012 | Cars & Trucks
Can you take a 1999 ford explorer cd player and use it in the 1996 ford explorer wire harness?
IF THE PLUGS MATCH UP YOU'RE GOOD TO GO! IF NOT, YOU MAY NEED A WIRING DIAGRAM, OR PLUG ADAPTER!
Feb 28, 2011 | 1996 Ford Explorer
I bought a 97 ford explorer and had to replace the drivers seat but the new seats the plugs are different not sure how to wire it
you have the wrong seat... you can use it but will have no electronic controls. trying to wire the wires in can be dangerous if there is an airbag in the seat. the other option is to switch seat tracks with the old seat if possible
Jan 18, 2011 | 1997 Ford Explorer AWD
Putting cd player in 94 explorer?? HELP PLEASE?!?!?!?
Yes, that would be fine, make sure you solder the wires and tape well or use shrink tube on the connections.
Mar 13, 2010 | 1994 Ford Explorer Limited
Ford Explorer 2002 Wiring diagram for radio/cd
I cannot eject a cd from the radio/cd player in my 2002 Ford Explorer. Do I need to take it to a repair shop or can I fix this problem myself? If so, how?
Dec 22, 2009 | 2002 Ford Explorer
Stereo system in 1994 ford explorer
I had this same problem.Took it to a friend and we bypassed the amp completely and ran new wires to all the speakers.
Aug 25, 2009 | Dual XDMR7710 CD Player
Ok my explorer was broken into and they stole my cd player but cut my factory wiring harness off so i need help hooking up another cd player to the factory wires without the plug
I suggest you go to a junk yard find another 2000 Explorer. Cut the radio wires and plug out of that truck. Then just match up the colors and attach that plug to your truck. I would suggest soldering the wires together to avoid problems down the line. Good Luck!
Jul 19, 2009 | 2000 Ford Explorer
Ford Explorer 2003: pioneer: factory 6 CD error
i dare say your cd player has had something move internally from the shock of the accident and thats whats causing the fault. lol either that or someone has gone and forced a 7th cd into it. i think the cheapest and easiest way to fix this would be to get a fascia kit and a new cd player beacuse ford will charge like a wounded bull for a replacement one. this is what i did after i serviced my car and got given the wrong code for the cdplayer from the ford dealership
Jan 02, 2009 | 2003 Ford Explorer
JVC KD-G230 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
