Question about Microwave Ovens
Why did my mocrowave oven suddenly stop heating food?
Homemaker model EM925EYP
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Feb 08, 2009
  • 623 Answers
SOURCE: food not heated in mocrowave
I'd say the actual microwave generator has gone bad.
Posted on Jun 05, 2009
  • 8404 Answers
SOURCE: My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Posted on Sep 07, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: microwave stopped heating food.
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
(if it is NOT shorted or burned looking, it's probably fine)
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Posted on Dec 25, 2009
Testimonial: "This answer was extremely detailed and helpful. I will pursue the different options soon. Thanks!"
SOURCE: GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Posted on Jan 20, 2010
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
Need a manual for a homemaker em925eyp microwave oven
I've saved a copy of my manual as a pdf. How do I upload it here? I don't really want to leave my email address here.
Mar 21, 2013 | Microwave Ovens
Microwaze suddenly stopped heating food, runs well but just does
take outer cover off look inline with the black wire
Aug 31, 2009 | Microwave Ovens
Food not heated in mocrowave
Jun 05, 2009 | GE XL1800 1100 Watts Microwave Oven
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave run with a different noise and stopped heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fkj
Samsung MD800SC Microwave runs but stopped heating
Chances are you have a bad connection, maybe the cook relay or at the magnetron, but feel free to write back with details when it fails again.
Aug 19, 2008 | Samsung MD800SC Microwave Oven
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
