Question about Fisher and Paykel Washing Machines
I have a Fisher& Paykel washing machine AWF 60 MD. The machin has, over time, become more difficult to start due to poor door latch. A registered technician came and said that the door mechanism
AWF 60 MD Fisher & Paykel door latch not working to enable machine to start. Door problem has been a slow progression. A registered agent came and said the door can't be replaced or fixed- we will need to buy a new machine- can you help?
  • 1073 Answers
SOURCE: FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
Posted on May 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Posted on Jun 19, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Front loading washing machine stuck on pause - won't restart
If your Fisher & Paykel Front loading washing machine stuck on pause, give us a call and we'll troubleshoot it over the phone or send a tech to diagnose it in no time. More info here : http://appliancerepair.biz/brands/fisher-paykel-appliance-repair/
Oct 17, 2014 | Fisher Paykel Fisher & Paykel Traditional...
Want 1 register warranty
Contact Fisher & Paykel directly via this contact page - and ask how to go about registering your product with them.
http://www.fisherpaykel.com/us/support/contact-us/
Mar 11, 2014 | Fisher and Paykel IWL12 Top Load Washer
Fisher & Paykel Intuitive IW709AU washing machine
this is a reset ok 1 open the door 2 put the program on the off position 3 turn the machine on 4 if you have a start button press it and hold it in for 2 mins then let go ,,,if you don't have a start button just go to follow the rest 5 put the power button on 6 shut the door it should do nothing then open the door put on you spin then shut the door wait till it finish ok job done hope this helped
Oct 18, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
My fisher and paykel washing machine will not finish its cycle with a minute to go,
Can you tell me if the w/m is pumping the water out.The washing machine will not spin until all the water is out.
I would need more information ? If you tilt the washer back on a 45degree angle,you will see the pump,looks like a black fan blade on your right side.the windings should look shiny' copper' not burnt looking or white,which indicates a water mark.See if you can move the black impeller and remember to up PLUG the washing machine?
Aug 14, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
I have a Fisher & Paykel 6.5 Excellence, my garage door had a mishap and the wiring blew and is now all melted, have found that my washing machine now does not go whch is more than likely due to the...
i am sorry to say there is no reset switch if u are geting power to the unit and the display is not coming on then u have a bad control board located in the front panel.
Apr 09, 2011 | Fisher and Paykel Fisher & Paykel Washer
The door on my front loader won't open it has done a 30min cycle
my fisher and paykel door is jammed and is stuck on 1 minute timing won't start
Jan 14, 2011 | Fisher and Paykel Fisher & Paykel Washer
I've got a fisher paykel gwl10 top load washing machine
Check the pipes leading to water pump for wetness also the door seal,If all pipes are dry and look ok then it could be due to the water seal and bearings braking down.
Jun 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Hi Dale..
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
