Question about Whirlpool ACQ189XM Air Conditioner
How do you put freon in a air temp air conditioner
    Problem Solver:
  • 6 Answers
You don't uless you know what you are doing!!!!
Where has the old refrigerant gone?
Posted on Jun 23, 2009
3 Suggested Answers
  • 31 Answers
SOURCE: punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Posted on Nov 17, 2008
  • 56 Answers
SOURCE: air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
Posted on Feb 12, 2009
Air conditioner blows heat, conditioner was charged, freon, checked relay switch, fuse, door blend alol fine still hot air, was told maybe a block in V shape hose is it temp control value Help
Only way to tell if A/C Evaporator Core Orifice tube is plugged is by looking at A/C gauge readings , An if it is plugged you more then likely need a new compressor , they become plugged with metal particles from worn out compressor. Your best bet would be to take your vehicle to a qualified repair shop .
Jun 27, 2016 | 1998 Lincoln Navigator
Why will my 1993 ford aerostar air conditioner will not turn on after i put in the freon?
You have to add 134a refrigerant while the engine is running and the A/C is on max with temp setting at lowest level. Without the proper charge in PSI, the compressor will not kick on. If the pressure is correct under those circumstances, You either have air in the system ( take it and have it pumped down then refilled) or the compressor is bad.
Jul 31, 2014 | 1993 Ford Aerostar Extended
Room temp 78 degrees with unit setting at 68 degrees. The unit is running (i.e. compressor) but unit not pumping out cold air. To be specific the unit is pushing out cool air just not cold with such a...
Sounds like it could be low on freon I believe these units have about 1.5 pounds of freon in them and are critical in not undercharging or overcharging them if it is a freon 410 ac unit the pressures should be about 135 and both lines cold if is low on freon a service tec will need to be called to try to repair the leak if possiable
Jul 21, 2013 | LG LAN240HSV2-LAU240HSV2 24000 BTU 20 SEER...
What the psig reading on a reach in cooler on lo and hi side
Hi, That depends on what refrigerant is used... there are about 10 different ones and they will all have different pressures...
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 06, 2011 | Refrigerators
How many PSI freon dos this unit take to fill? S3QA-30KA 2.5 TON
unit's are usually charged in pounds not psi...units require a certain pound amount of freon to work properly....... it depends on the outside air temp, the inside air temp.... what type freon ?? need more details on unit and what type freon does it use??
May 10, 2011 | Heating & Cooling
Poor cooling
cold air is made by refrigeration in the air conditioner. If the unit is low on the freon charge then you have a poor exchange and poor cooling. I have gotten the units to work better by putting a little water on the outside exchange coil. by bringing the temp down on the outside coil you get a better exchange and better cooling. I used a small copper tube with about 10 real small holes in it to drizzel just a little bit of water on the outside part of the machine. the fan cools off the outside coils off and gets a better exchange bringing down the temp of the air coming out of air conditioner
May 01, 2011 | Heating & Cooling
What is the expected air temp on a Duo Therm Roof Unit? Also can they be recharged? Thanks!
They should run 50 -55 F or about 20 degrees less then the indoor air temp... and yes they can be recharged.....
http://www.fixya.com/support/r5638346-add_freon_air_conditioner_or
heatman101
Aug 23, 2010 | Dometic Rooftop RV Air Conditioner
2001 Saturn L200 Air conditioner issue
You need to make sure the freon is correct,by having ac gauges put on the system,if the compressor is running the gauges will tell if there is a problem with the ac system itself,now,it can be the temp door actuator motor that is in the dash,if it is not moving the temp door open,it will need to be replaced.
May 27, 2010 | 2001 Saturn L-Series
I have a 1999 Volkswagon Passat. The air conditioner works great at night or when the outside air temp is below 80°; it will put out 55° air. But during the day it will only put out 10°...
check to see if you have a cabin air filter and if it is dirty have it replaced at a local auto shop.. if that isnt the problem and the freon level is correct then you will have to live with it.. a/c are concidered effiectient if they cool 20* below ambiant tempature.. personally i would say have the freon level/quality checked again
Aug 03, 2009 | 1999 Volkswagen Passat
Whirlpool ACQ189XM Air Conditioner Logo
184 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
