Everstar Portable Air Conditioner MPK-10CR how do i put water in it
5 Suggested Answers
  • 6 Answers
SOURCE: water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
  • 37 Answers
SOURCE: My Everstar MPK-10CR portable 10,000 BTU's is blinkink P1 all tim
Make sure the level arm is also making good contct with the water bucket when you insert it. You can awlas pull the level towards you to adjust for better contact.
Posted on Aug 21, 2010
SOURCE: I am looking for an air vent hose for an Everstar
is there a vent hose that is insulated the reg. one gets too hot defeating the purpose of AC
Posted on Jun 15, 2013
  • 3 Answers
Just got one of these used, and also got the P1 error. Took the case off (which just involved a lot of Phillips head screwdriver turning), and found a sensor switch just to the left of the drain box inside the case. If I press on the sensor switch, the P1 error goes away, but then I get a blinking dot on the LCD display. Pressed the power button after that (while still holding the sensor switch) and it started working again. It looks like it was super-glued either originally or by a previous owner. Just needed to be re-positioned towards the top left corner where the drain pan sits. Just be careful when removing the case to not disconnect any of the wires going to the LCD display.
Posted on Aug 05, 2014
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
What are the wire connections?
Hallo
Please send me a picture of the two wires.
I need to see it to tell you.
Jun 09, 2016 | Everstar Portable Air Conditioner MPK-10CR
Unit is making a grinding/rattling sound on and off with more use. How do I fix this?
Its a bearing problem could be the motor could be the fan this is a portable and dose need to level and sucured enough not to tip .
Grinding /rattling is the definition of a bad bearing.
Jun 02, 2015 | Everstar Portable Air Conditioner MPK-10CR
I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
Jun 20, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
