Question about Refrigerators
Viking vcbb363 bottom freezer. alarm went off a week ago. control panel show red light and now the freezer isn't real cooling all that well. cool but not cold. I tried turing off the unit and restarting. the same thing happened again. beeping alarm, orange signal on control panel and the freezer still isn't really cold - ice cream is soft.
  • 10,515 Answers
Well lets see providing the freezer fan works remove the bottom of the feezer I am guessing this is a standard admiral frig with the evap in bottom and not across the back. These fridges have a glass tube defrost heater that gets moisture in them and burns out the heater and leaves broken glass that housed the heater in evap tray if it's heavily frosted thaw it out so you can find the leads to the heater to check it with a meter. Sometimes they will be so iced up the bottom freezer panel is hard to get out....or you can find the timer advance it in a defrost and clamp on an amp probe to the common and it should draw around 4-5 amps.
If it's defrosting fine, makes ice and the fresh food section is cold as normal then I would assume it's your 'defrost thermostat'.
Also check Compressor.
Just to add another possiblity, the thermostat itself maybe about shot. Thus running constantly and not cooling properly
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
Freezer not cooling properly. Temperature alarm went off. Turned off now.
Look inside freezer on the rear wall to look to see if there is frost buildup. If yes then unplug and manually defrost defrost for about 3 hours if you only open freezer or place hot water in a bucket and place inside freezer and close the door. Let me know by answering my post here, Thanks John T.Appliance 911
Contact
click below for parts breakdown
I have a feeling the problem could be 1 of three things=> WR9X520 Defrost Timer, WR51X465 Defrost Heater or the WR50X0131Defrost Thermostat
May 28, 2015 | Viking Professional VCBB363 Bottom Freezer...
Frigidaire 20 cu ft. upright freezer went out a few days ago. Discovered bottom seal was not in place but fixed that. Alarm light stayed on through the night and freezer is not cooling AT ALL although...
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Aug 08, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Every six weeks the alarm sounds, that's when we know it is time to take out the freezer drawer, remove the back wall cover and begin to defrost the ice that has built up. put it We put it back...
no such thing as unrepairable
if coils behind fc panel were snowed over solid most likely need defrost limiter about an 80 part
take grill off up top
two Phillips screws hold white plastic panel that user interface is on
wiring , programing service manual in envelope attached to back side of panel
Apr 04, 2017 | Viking Professional VCBB363 Bottom Freezer...
Door open alarm sounds and door open indicator blinks, but refrigerator door and freezer drawer are closed. Alarm stops when you press Alarm Off pad, but door indicator continues to blink until it times...
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Viking Professional VCBB363 Bottom Freezer...
Ice freezing on bottom of freezer drawer
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | Viking Professional VCBB363 Bottom Freezer...
Freezer not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Viking Professional VCBB363 Bottom Freezer...
Refrigerator and freezer not cooling
sound like side by side check compressor for starting up check defrost timer
May 30, 2009 | Viking DFBB363 Bottom Freezer Refrigerator
Noise at the top, constant
Are you saying you get the noise even when the refrigerator is not cooling? If you get the noise only when the refrigerator "runs", it is the fan as you suggest.
Apr 28, 2009 | Viking Professional VCBB363 Bottom Freezer...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
