Question about Robin Subaru Electrical Supplies
I'm looking for a fuel tank for an Robin weed eater NB02-3
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
#1 Taper
  • 1040 Answers
SOURCE: need diagram on fuel lines on a 26 cc craftsman weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
Mickgiever
  • 146 Answers
SOURCE: I used poulan 2 stroke weed eater engine oil in a
Check your fuel mixture and remove the spark plug and clean it.
Posted on Aug 19, 2009
  • 62 Answers
SOURCE: poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Posted on Sep 25, 2009
MOTORWIZJ
  • 1363 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed Eater GTI 19T
    If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
    Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
    change the fuel lines over on the carby
    you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
    Mar 12, 2017 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
    Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
    Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
    What is the purpose of having two different size fuel lines in the fuel tank on a weed eater trimmer ?
    Weed eaters have a diaphram operated carburetor instead of the float operated ones on a lawnmower. The bigger one is the fuel to the carburetor and the little one is the return to the tank from the carburetor.
    Jul 27, 2011 | Garden
    Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
    be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
    Jul 08, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Can't find fuel filter on Poulan Pro weed eater. Acts as if it's fuel starved
    Where is the fuel filter?
    All gasoline engines have a fuel filter on the end of the fuel line in the fuel tank. Weed Eater recommends changing the fuel filter yearly. To remove the filter,
    1. drain the fuel from the unit,
    2. Pull the filter from the tank through the gas tank opening and remove it from the line,
    3. Install the new filter on the fuel line and drop back in tank.
    Jul 08, 2009 | Poulan Garden
    Fuel hoses routed wrong on weed eater fuel tank
    Apr 04, 2009 | Garden
    Electrical Supplies Logo
    23 people viewed this question
    Top Robin Subaru Electrical Supplies Experts
    ken skalski
    Gene Haynes
    Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
