Question about Garden
Uberhaus shower 80475021
The shower elbow is too long, do you know what can I do?
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
I installed a uberhaus tub and shower faucet luna series and I don't have the instructions the water won't shut off when I turn the handle to off
you might have the cartridge turned 180 degrees out of alignment. remove the handle, and carefully rotate the stem until the water shuts off, then re install the handle in its appropriate position.
Mar 26, 2015 | Home
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
Uberhaus faucet
needs new Oring kit
Sep 20, 2013 | Garden
Uberhaus bathtub and shower faucet 81585016 problem
The reason is because they built this wrong and Rona still decides to sell it. I have one in the wall that I am stuck with. Call up Mecanair, the rep for uberhaus and the they will tell you its not a mistake to have HOT water come out when the handle is at the C position.
Mar 06, 2013 | Home
COULD YOU PLEASE TEL ME HOW TO INSTAL MY SHOWER
ok! run hot and cold water pipes to faucet.up through the wall. hot on left, cold on right. on center of faucet run a pipe straight up where you want it. put a elbow on top of this pipe to hook shower spout and head too. just screw spout to elbow whitch comes through wall for shower head. the best thing to do is on the back side of pipes is have an opening to get to pipes if anything goes wrong in the future. just put up a temporary panel that can be removed easily. or shevles that can be removed. you can buy the faucet at home depot etc. if need any more info, just e-mail me or repost. toolman1862001@yahoo.com, good-day!!
Aug 25, 2011 | Home
The device the sprayes water from the shower head has broken. The shower head does not unscrew for the shower arm. The shower arm is attached behind the tiled wall. How do I remove the shower arm and...
The shower arm should be screwed into an elbow inside the wall. Unscrew the shower arm by putting your pipe wrench on the arm and unscrewing in a counter clockwise direction ( lefty loosey, righty tighty ) . Measure the length of the arm going inside the wall and make sure your replacement has enough length to reach. Teflon tape the inside end ( the end going in the wall ) and wrap a rag around the new arm, then screw into the elbow going clock wise , stopping when it starts getting tight and with the bend facing downward. Install shower head.
Nov 20, 2010 | Price Pfister Home
My shower stall has a crack on the floor,i dont know if there is a apn underneathe to prevent rotting on wood
If your shower stall has a crack in the bottom, you may be able to see if it is getting the wood wet by looking under house. But even if it is not leaking there now, it will eventualy become a problem. I would suggest that you make some repairs or hire a proffessional soon. I hope this helps.
May 09, 2010 | NRS Jones Stephens Corp. S01-050 Shower...
Tub shower combo... newly installed but leaks from shower head when turned on
Some shower heads require a rubber washer that would fit in the opening in the shower head. That may be all you need and would be the simplest fix. Check that first.
Sounds like you need some teflon tape available at any hardware store. The teflon tape should be wrapped around the pipe threads with 2 or 3 wraps and then screw the shower head on to the pipe. If the leak is in the wall, remove the shower head pipe from the wall pipe elbow and apply 2 or 3 wraps of teflon tape to the shower head pipe threads and reinstall to the elbow in the wall. You may need a pipe wrench if the pipe is real tight. Good Luck
Nov 30, 2008 | Dishwashers
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
