Question about iRobot Roomba 560 Robotic Vacuum
How to clean roomba - iRobot Roomba 560 Robotic Vacuum
Changing the language on roomba pet series
You need to post a model numbers before I can help you.
Now, a three second search of the roomba help section on the roomba website turned up this:
All Roomba 700 Series and select 500/600 Series can provide troubleshooting messages in either English, French, German, Spanish, Italian, Dutch, Danish, Swedish, Norwegian, Finnish, Polish, Russian, Portuguese, Japanese, Korean, or Chinese.
Roomba's default language is English.
700 Series: Instructions for Setting the Language
  1. Turn ON your Roomba by pressing CLEAN.
  2. Press and hold DOCK until it beeps and says the current language.
  3. Release DOCK. Roomba is now in Language Selection Mode.
  4. Now press CLEAN repeatedly until you hear the language you want.
  5. Press and hold CLEAN to turn off your Roomba and confirm language choice.
500/600 Series: Instructions for Setting the Language
  1. Turn OFF Roomba. (Press and hold CLEAN until Roomba's lights turn off.)
  2. Press and hold CLEAN until Roomba beeps and says the currently selected language.
  3. Release CLEAN. Roomba is now in Language Selection Mode.
  4. Press CLEAN repeatedly until you hear the desired language.
  5. Press and hold CLEAN to turn OFF Roomba and confirm the language choice.
Jan 25, 2014 | iRobot Roomba 550 Vacuum
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    I have no instructions for my roomba 560 so dont know how to start it
    Turning Roomba on and off • To turn Roomba ON, press CLEAN once. You will hear a beep and the CLEAN button will light. • To start a cleaning cycle, press CLEANagain. Roomba will start a cleaning cycle. • To pause Roomba, press CLEAN while Roombais cleaning. • To turn Roomba OFF, press and hold theCLEAN button until Roomba's lightsturn OFF.
    Sep 21, 2011 | iRobot Roomba 560 Robotic Vacuum
    I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
    TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
    Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
    Hope this helps. If it does, I would appreciate a vote. Thanks,
    Handie Andie
    Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
    It starts and for a few seconds and then stops The battery is fine
    Is the charging ase turned on and is the dust container emptied? Any obstructions?
    Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
    Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
    I had the same problem. You must clean this parts and inside this parts:
    Remove hair with cleaning tool
    Remove Roomba's brush bearings
    Clean Roomba's brush bearings with cleaning tool
    Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
    ERROR MESSAGE
    When Roomba says "Please Inspect and Clean Roomba's Cliff Sensors" it means that Roomba 500 series sees a constant cliff.This can happen if Roomba was started on an uneven surface or got stuckon an obstacle during the cleaning cycle. Extremely dark-colored floorsurfaces may also contribute to this error. If this error occurs on aneven, light-colored floor surface, Roomba’s Cliff Sensors could be dirty or obstructed.To troubleshoot this issue, please follow these steps:
    1. Check the Cliff Sensors for obstructions.
    2. Clean the Cliff Sensor windows using clean, dry cloth.
    3. Move Roomba and restart in a new location.
    The location of the (4) optical sensors can be seen here:
    Occasionally these sensors do go bad and that can be a hassle since iRobot doesn't like to sell replacements...they prefer you send the whole robot back to them. If you are handy and willing to replace yourself, you can purchase replacements from some reputable vendors like www.RoboticVacParts.com
    Jun 07, 2009 | Roomba Robotic Floor Bagless Vacuum
    Please clean Roomba s brushes warning will not stop after brushes have been cleaned Unit shuts off after one minute of cleaning
    Clean the yellow brush bearings. Then run the Roomba without the dustbin, so that you can watch the brush while the unit is cleaning. Is it turning? If not, call customer support. 877-855-8593. Have your Roomba with you; they will want information from it. Good luck.
    Dec 13, 2008 | iRobot Roomba 570 Robotic Vacuum
    Roomba 4200 Scheduler
    The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
    Clean every part, maybe a hair slow down the wheels and thats why need more power.
    Here some tip from the web:
    With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
    Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
    Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
    Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
    Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
    Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
    Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
    Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
    Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
    You can purchase a second battery or replacement online at the iRobot Store.
    Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Open Questions:
    See all iRobot Roomba 560 Robotic Vacuum Questions
    iRobot Roomba 560 Robotic Vacuum Logo
    41 people viewed this question
    Top iRobot Vacuums Experts
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
