Question about Mitsubishi WD Televison & Video
How do i fix a mitsubishi hdmi model number wd-73640 wont come on red light
Wont come on red light on only
  • 3 Answers
SOURCE: Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Posted on Jan 11, 2009
  • 125 Answers
SOURCE: 4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Posted on Mar 20, 2009
SOURCE: Mitsubishi HDTV model wd-62525 has
It has been renamed.
Posted on Mar 22, 2009
  • 60 Answers
SOURCE: MItsubishi DLP HDMI HDTV WD-62525 Steady RED
  1. Call Mits. and see if they will cover the main chassis rebuild then call an authorized service center to pull the chassis will take 4-8 weeks for it to be rebuilt but you will be resposible for labor
Posted on Aug 25, 2009
localwonder
  • 6784 Answers
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Posted on Sep 02, 2009
My mitsubishi WD73640 keeps randomly losing it's source signal, the tv will go black,then hdmi window will appear then all will restore
Check the HDMI cable make sure it is fully seated or better yet get another one. You can get them on eBay for a few $'s
Nov 25, 2016 | Mitsubishi WD-73640 73-Inch 1080p...
Mitsubishi tv WD-73640 wont turn on. 4 red light then 8 yellow lights
Hi, if you power your TV on and see a black or grey screen, it may be on the incorrect input. Inputs get changed when switching the TV input for dvds or video game consoles. Look for a Source or TV Video button on your TV remote, not the cable remote. Before doing this, please make sure all connections are secure. I hope this helps or reply with more questions.
Jul 26, 2016 | Mitsubishi WD Televison & Video
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
I HAVE MITSUBISHI WD-73640 AND ITS SHOW THE GEEN LIGHT BUT DOESN'T HAVE PICTURE OR SOUND
The first thing to replace is the lamp. Google your model number and "lamp" and you'll find several sites that sell them. It isn't difficult to replace yourself and isn't very expensive. Good luck.
Sep 25, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
Looking what i can do to fix. Have a Mitsubishi TV 3D DLP WD-73640, Replaced bulb, and still have the red LED flashing 6 times to the Yellow led flashing 1.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Check the lamp ballast too.
Aug 14, 2014 | Mitsubishi Cinema WD-73640 73" 3D DLP...
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
Black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Dec 31, 2013 | Mitsubishi Televison & Video
White lines that are constantly on will go away for a few seconds then pop back up.. Mitsubishi 73" model number WD-73640
You need to replace the 4719-001997 DLP Chip. this should solve the issue.
This chip can be expensive so look around before you purchase. This is a common problem with these TVs, both white lines and white dots. You can find out how to replace the chip by going to this website: http://www.fixyourdlp.com/2012/09/04/solve-the-mitsubishi-wd-73640-white-dot-problem-with-a-new-4719-001997-dlp-chip/.Hope this helps
Feb 27, 2013 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
