Question about Magellan Roadmate 5045 3065 3055 3045-LM 3045-MU 3045 2045 2036-MU 2036 2035 GPS Vent Mount Kit by C...
How to stop my gps from restarting to enhance profromace
Loops from message to restart to improve performance to restart to the message again...repeats the process. Only way to stop it is to shut it off.
Try re booting, turn off like normal, then when you go to turn it on, hold power button down all the way through the start up, and 15 seconds more than release the on button, now it's rebooted, see if that helps, let me know.
Jun 11, 2011 | Magellan Roadmate 1445T GPS Receiver
Wont stop loading maps
If your garmin nuvi wont stop loading maps, then you need to reaet the unit to get it to work perfectly fine once again. Try to hold down the power button for about 15 seconds and the gps receiver will restart, this time it will load normally and show you your maps.
If that does not solve the problem, then you need to back up your maps then format your gps receiver from a computer then restore the software and maps back on, that should do the job for you.
Hope this helps.
Dec 23, 2010 | Garmin Nuvi 465T Car GPS Receiver
How do I turn the Bluetooth on to use with my I phone
Turn on your Nuvi, go to Tools in the next screen you should see Bluetooth..... go to Connections and Add Device
Once added make sure Bluetooth says Enable
Oct 19, 2010 | Garmin nuvi 205W GPS Receiver
Programming the Garvin to work with a Bluetooth phone
as far as i remember there is no bluetooth on this unit.
May 04, 2010 | Garmin nuvi 255W GPS Receiver
Map update terminated. cannoty restart update.
reset button on base press with soft pen, retry the if no good contact garmin for reissue of update
Dec 27, 2009 | Garmin nuvi 205W GPS Receiver
I have tomtom 920 and the issue is . 1- It will restart at startup and can?t find GPS. 2- After restart it will stop home page until i restart it. 3- Will not charge 100% 4-toch screen will not respond at...
I recommend to follow TomTom (Support) answer to that question:
"If your navigation device gets stuck after you switch it on, the TomTom application is not installed (or corrupt) or cannot be found (parts of the application). Your device then only shows the start-up image or a flashing cross".
Jul 06, 2009 | Tomtom Go 920T GPS Receiver
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
Synaptics Touchpad Enhancements stops working
Hi!
I resently had the same problem on my HP laptop and search Google for possible solutions. No solution works until I tried Windovs Update and then got 5 alternatives - Synaptics PS/2 port TouchPad was one of them. I update and restart and finally solve this problem.
Terje
Jan 09, 2009 | Acer Aspire 3610 Notebook
Cursor bouncing
I have had some similar issues, I find I must wait till my mapping program is fully open and running before I plug in my GPS unit, and the problem doesn't resurface.
Oct 25, 2007 | Microsoft Deluo Universal GPS USB...
Magellan Roadmate 5045 3065 3055 3045-LM 3045-MU 3045 2045 2036-MU 2036 2035 GPS Vent Mount Kit by C... Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
