Question about Thule 2008 Dodge Dakota - Quad cab - Xsporter Truck Rack
How do you change a rack and pinion on a 2008 dodge dakota
    Sergeant:
  • 273 Answers
Very carefully and slowly. use a neighbor's driveway and jack up the car and place wheel jacks under the front assembly.
Posted on Jun 22, 2016
Will a 92 dodge Dakota rack and pinion fit on my
1992 dakota does not have a steering rack
I had a new one for 18.5 years
Oct 03, 2014 | 1999 Dodge Dakota
How to replace seals on 1997 dodge dakota rack & pinion
You don't,never have
Have to replace the rack & then install
a return line filter ,after the system is flushed
in order to warrantee the new rack
The have it aligned
Aug 11, 2013 | 2003 GMC Sierra 1500
Rack and pinion boot is leaking,how to fix it
It requires replacement of the rack and pinion assembly, since the seals are most likely worn out and leaking.
Aug 02, 2013 | 1992 Dodge Dakota
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Rack and pinion? have play in wheel no sign of leaks new power steering pump installed
Hi Gunny, If your vehicle is fitted with rack and pinion steering also check the rack ends for play. The rack ends are the rods which the tie rod ends screw onto. The other end fits onto the rack of the rack and pinion. To work on those you will need to remove the rubber boots and loosen the locking washer, they can then be loosened with a wrench. If they are worn the play will be evident in the steering. When replacing them also replace the rubber boots. If the boots are worn and road grime and dust enters, you will see leakage from the rack and pinion in the near future. I always thought the Dakota was fitted with a steering box? Regards John
Jun 24, 2012 | 1990 Dodge Dakota
Steering is realy touchy need to slow it down on dodge dakota 1997 rack pinion was wondering how to adjust it or if can it acts like it is getting to much pressure to the rack
This could be a couple of things, most like none of them to do with the steering gear itself. If you are used to older types of steering systems that use connecting rods/idler arms/pitman arms, you will need to adjust to the faster response of a rack and pinion steering system. If the problem is that the vehicle seems to "jump" when you give the least bit of pressure to the steering wheel, it could be one of a few things. Tire pressure or belt separation can cause handing issues. Improper alignment, even if the vehicle seems to have no issues with left-or-right pull, can cause erratic steering performance and can amplify issues with hydroplaning in wet conditions. If you have had steering parts replaced, or changed and/or rotated tires recently, I would check those areas first. Lastly, I would ensure that you are using the correct power steering fluid in your rack. Many people use DEXRON ATF, but that is not the recommended fluid for the Dakota rack.
Sep 14, 2011 | 1997 Dodge Dakota
Does dodge offer a rack and pinion steering reduction box
No,at least not at this time,ckeck with some after market vendors
Jul 19, 2009 | 2007 Dodge Ram Truck
Steering hard in 97 dodge dakota
This problem is always caused by a defective rack and pinion steering unit, flush the system and replace the rack.
Jun 03, 2009 | 1997 Dodge Dakota
1999 dakota rack and pinion leak
You can change the seal, but the new one will most likely leak soon after, the seal starts leaking because of problems in the rack from wear, I would try it but if it leaks soon after replace the rack, they are cheap rebuilt.
Apr 02, 2009 | 1999 Dodge Dakota
Thule 2008 Dodge Dakota - Quad cab - Xsporter Truck Rack Logo
236 people viewed this question
Top Thule Boating Experts
Tom Chichester
SriPhi
ray gallant
Are you a Thule Boating Expert? Answer questions, earn points and help others
