How to make water drain from arctic king air conditioner?
Where is the drain hole on the arctic king air conditioner?
the dr
  • 447 Answers
SOURCE: Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Posted on Sep 29, 2007
  • 31 Answers
SOURCE: punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Posted on Nov 17, 2008
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Posted on Jun 23, 2009
icemelts
  • 246 Answers
SOURCE: The drain hole is in the window sill, not the back
I'm not sure why that drain hole is located where it is - but in any case - you're going to have to plug the existing hole and re-drill another drain hole at the back of the unit.
I would plug the unwanted hole with a 'liquid steel material,' i.e. JB Weld or something similar.
Note: be careful when re-drilling the new drain hole and don't drill a hole in your condenser.
good luck!
Posted on May 04, 2010
  • 2976 Answers
SOURCE: My FAC104 P1A window air conditioner does NOT
Some don't have a drain hole anymore. As long as you have it tilted slightly, any excess water will drain out. If your house or room feels good, it's working. It won't pull moisture out of the air if the air has already been dehumidified.
Posted on Jun 28, 2010
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
Beaumont/Artic King Air conditioner model # MWK06CRN1-BJ7
First make sure that the unit is leaning out and check the weep hole for dirt and clear or clean if needed.
Jul 02, 2016 | Heating & Cooling
Is there any kinds of problems with this air conditioner
Here are some reviews and questions that have already been asked on Fixya. any appliance that is only used for a few months of the year and then rests for months is going to exhibit some problems eventually. Usually just a matter of getting an AC engineer to add some more refrigerant gas.
  • Amazon.com: Customer Reviews: Arctic King MWK-06CRN1 ... www.amazon.com/Arctic-King-MWK-06CRN1-BJ7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-06CRN1-BJ7 6,000 BTU Window Mounted Air Condit at ... COOL AIR coming out of the Artic King.
  • Amazon.com: Customer Reviews: Arctic King MWK-05CMN1 ... www.amazon.com/Arctic-King-MWK-05CMN1-BI7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-05CMN1-BI7 5,000 BTU Window Mounted Air Condit at Amazon.com. Read honest ... by Arctic King...
  • Review of my Arctic King 5,000 BTU Air Conditioner - YouTube www.youtube.com/watch?v=oaB2CPeZLTs
    • BY GOLDENSONIC08
    • 7 MIN
    • 20K VIEWS
    2014-06-09 · Video embedded · Just a quick review of my Arctic King WWK-05CRN1-BI7 5,000 BTU air conditioner.
  • Arctic King 10,000 BTU Energy Star Window Mount Air ... https://jet.com/product/Artic-King-10000-BTU-HomeOffice-Window... This Arctic King Air Conditioner is designed to be installed in a standard double ... This 10,000 BTU window mount Arctic King Air Conditioner is one of the most ...
  • How to Repair Window AC ' eBay www.ebay.com > ... > Heating, Cooling & Air > Air Conditioners A window-mounted air conditioning unit can be a lifesaver for anyone in ... How to Repair Window AC. ... Arctic King 8,000 BTU Energy Star Window Room Air Conditioner ...
  • ACE Artic King Window Mount Air Conditioner 5,000 BTU ... www.fixya.com > Forum > Air Conditioners > ACE Recent ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK-05CMN1-B, 1 ea questions, problems & answers. Free expert DIY tips, support, ...
  • ACE Air Conditioner Problem Support, Troubleshooting Help ... www.fixya.com > Forum > Air Conditioners ... Manuals & Customer Service for ACE Air Conditioners. ... ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK ... ACE Artic King Window Mount Air...
  • Jun 09, 2016 | ACE Artic King Window Mount Air...
    I lost n need to buy window mounting kit for arctic king 5,000 btu window air conditioner. Do u guys carry it?
    This is a question answering site, not a store. Check with Sears, Amazon or Walmart for the parts you need. They appear to carry Arctic King air conditioners. Sears Parts Direct probably can get it for you.
    Jun 15, 2015 | Heating & Cooling
    What is the consumer telephone number for Arctic King Air Conditioners?
    This is what is provided to US customer service:
    Contact Us
    It has the phone numbers, fax numbers, and a way to email them.
    Jun 28, 2014 | Arctic King Heating & Cooling
    Why did my 5,000 btu artic king air conditioner stop working after having it less than one day?
    Can't answer why as no details as to how it's failed, but if you've only had it a day return it to the vendor.
    you have installed it as per instructions? Is it draining ok? No error codes? Checked the power outlet? Fuses or breakers?
    Jun 17, 2014 | Arctic King MWK-05CMN1-BI7 5,000 BTU...
    Where is my water drip pan located in my arctic king wall unit air condtioner? it's leaking water in the inside of my house.
    it is behind the evapator unit that you see behind the filter. under neath of it is a pan it sits in. and the drain is located usually in the middle . But be certain that the unit is tilted to the outside agiout 1 inch or so.. check the filter and while your at it service it ... hope this helps let me know
    Jul 23, 2011 | Heating & Cooling
    Heating & Cooling Logo
    2,805 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
