Question about LG enV VX9900 Cellular Phone
CHARGING PORT I LOVE THIS PHONE, IM ON MY SEOND ONE, FIRST ONE WAS LOST W AND CHARGING PORT PROBLEM, THOUGHT IT WAS MY PHONE. GOT A NEW ONE W INS. NOW THE SAME THING IS HAPPENING WITH THE PORT. IM PISSED, CALLING VERIZON I HAVE GOTTEN THREE NEW CAR CHARGERS, AND A NEW WALL CHARGER. THERE SHOULD BE A RECALL ON THIS PHONE!
    Problem Solver:
  • 10 Answers
Have you checked the pins inside your charger port? Are they not in the middle? If yes, you might want to try to fix it first yourself by using a knife or something skinny that would fit into the port. The pins inside your charger port must have been shifted (pushed up or down). The plug, once inserted does not go all the way through or is not fully inserted within the port. Use a butter knife (this is what I used) or something flat and skinny that would fit into the port. Then, push it down or up to the middle. Try connecting the plug and check if it's now charging.
Posted on Jun 23, 2009
My iphone 2g wont charge at all
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 05, 2012 | Apple iPhone Smartphone
Every 5 minutes or so it beeps and says it is not charging although the phone is not even plugged into the charger. When you switch it on at first it says it is charging with the bar graph indicating this...
Hi, would have told you too replace two things on the phone,
The charger and the battery.....
But sometimes the charger port where the charger is being inserted into the phone might be faulty too,
So you will need to test for the charger port. Get a new charger and a new battery, and insert the battery and plug in the charger...if nothing happens, that means you will need repair the charging port....
Consult a phone repairer for help...
Hope that helped...
Feb 03, 2011 | Nokia 6110 Cellular Phone
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
Problem with charger headset port. it became loose.
ok im having the same problem, im thinking of getting a new charger and or buying a new charging connector for the phone (where the charger/headphones plug into. You can get them on ebay for about $4 US.<br /> hope that helps?
Jun 22, 2010 | Sony Ericsson P1 Cellular Phone
The charger port on my lg voyager is frayed. If i buy anew charger port, is it easy to install? i thought it was my battery, so i bought a new one on Amazon. put the battery in and it worked fine. i have...
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
May 27, 2009 | LG VOYAGER VX10000 Cellular Phone
Charging error, stop charging! with "!"
I have had this problem before so dont worry, i found that i had to take out the chip and batery and air it out aswell as the the place were the charger fits, place them back in and try to charge up again.
Dec 28, 2008 | Sony Ericsson K800i Cellular Phone
Phone not charge.
right this happened to me too
its the charging port the pins in it are crushed and when you put in a charger it just pushes them of the plastic so they cant charge
basicly it the charging port
Sep 16, 2008 | Samsung D900i Cell Phone
LG enV VX9900 Cellular Phone Logo
173 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
