Question about Boating
Why won't my suzuki 60 hp outboard start
Battery is charged but when I turn the key all i hear is a click. It does not try to turn over. The engine is in neutral.
  • 127 Answers
SOURCE: Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Posted on Jun 26, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
wayneman01
  • 301 Answers
SOURCE: Kawasaki Mule 500 KAF 300 starter will not work below 60 degrees.
Using a lighter viscosity engine oil can make all the difference. Try something on the order of a 5W-30 for ambient temperatures of 60F or below. Of course, it could also be that your starter solenoid is in the early stages of failure. You can easily check it by using a large screwdriver to bridge the two large cable connections on the top of the solenoid. If the starter spins when you do this, then the solenoid is bad.
Posted on Dec 07, 2009
kcarmax
  • 30 Answers
SOURCE: 2001 BMW 330i wont start. Immobolizer?
Sounds like a dead battery or a dead starter. Try using a jump box or jump start first.
Posted on Feb 28, 2010
  • 91 Answers
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
40 HP 2 cycle outboard. Tilt works, but engine does not turn over. Yamaha outboard should mention.
So either the battery needs charging, the starter button / key are faulty, or the starter/solenoid is faulty. You need a test meter.
Dec 30, 2016 | Boating
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Suzuki4stroke 150 hp will not start, new battery gets juice just clicks
starter solinoide sounds like it failed if its clicking ! remove engine cover and as a friend cranks the key listen where the click is and it will have the +wire from battery and then a wire to starter , check connections are tight and if all ok then replace solinoide !
Sep 07, 2014 | Suzuki Tilt Trim Motor, DT 150-200...
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
Suzuki won t start
no crank!, if it cant crank, it can never start.
can be many thing.
1: dead battery or dirty terminals.
2: discharged battery (charge it or try test known good battery)
3: bad starter system.
Every way, possible , is here
http://www.fixkick.com/nocrank.html
May 09, 2013 | Suzuki Vitara Cars & Trucks
Nothing turns on when I turn the ignition on
Hi, Josh before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
MY Katana 600 Won Start it won even Click
What to do When Your Motorcycle Won Start
OEM parts for Suzuki
Suzuki GSX 600F 2000 Owner Manual
Suzuki GSX600F Service Manual Page 2
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 11, 2017 | 2002 Suzuki GSX 600 F (Katana)
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
May 30, 2012 | 2005 Nissan Altima
We have a mercury 60 2stroke outboard engine and nothing happens when you turn the key to start it
go through the basics first: is the kill switch on, battery switch on, battery charged, are the battery cables clean? if not these then most likely the starter solenoid or the key switch itself
May 09, 2010 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
69 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
