Fills up with little water turns once then stops
I reveresed the wiring on the solinorde valves but still doesnt work whirlpool awm1204/4 AA 1200
    President:
  • 1,294 Answers
You need to change the solenoid valves. The valves malfunction, hence low water, machine stops.
Posted on Dec 28, 2007
Whirlpool DU943PWKQO BUILT IN DISHWASHER WILL NOT FILL
It sounds like the inlet valve for the hot water , if you turn the water off remove the two wires going to the valve remove the valve, you have to remove the water hoses I think they are 1/2 " wrench, it comes a part easy it may just be clog up with junk , be carful of the rubber gasget , this is an easy fix I am sure you can do this , also always turn power off first !!!
Nov 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool, WTW5560S0-R stops filling, can hear humming
yep sounds like the solenoid on the valve is faulty, so you are quite correct there, as the humming indicates power is going to it but the plunger inside the solenoid is stuck, before you go replacing the valve try these little things first just in case, first try adjusting the water pressure up or down by turning the tap sometimes too a high pressure can cause the valve to jam shut, next thing to try is take the water inlet hose off the back of the machine and just have a look at the little mesh filters in the end of the valve (part where you screw the hose onto) as they can sometimes block over if the water is a little dirty, hope this helps you get back to me if you have any question
Nov 11, 2011 | Whirlpool Washing Machines
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
Leaking into tub
YOU NEED TO REPLACE THE WATER INLET VALVE AS ONE OF THE SOLINORDS IS NOT CLOSING ALL THE WAY,GO TO SEARS .COM CLICKON PARTS PUT IN YOUR MODEL NUMBER AND YOU CAN ORDER THE PART YOU NEED,LET ME NOW HOW YOU DO-MIKE
Nov 01, 2008 | Whirlpool GHW9100L Front Load Washer
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jul 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Ice maker
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker stopped making ice
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not workin
ok as far as the water in your door goes sounds like the micro switch is getting a little gummy and sticking this happens when people dump ice in sweet drinks and some splashes up locate the switch and spray a little wd 40 on it as to you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
