Question about Canon MX882 All-In-One InkJet Printer
How to replace purge tank for canon MX882 - Canon MX882 All-In-One InkJet Printer
Need a manual for a Canon Pixma MX882 printer
Try Googling (canon)(MX882)(manual) without parens.
Jun 09, 2017 | Canon Office Equipment & Supplies
Canon printer error code 6A81
Solution 1: This is a purge unit error.
There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly.
Try to move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit.
There maybe crumpled paper jammed in the purge.
If all looks well, the purge unit may be defective and had to be replaced.
Solution 2:
The wiper on the purge may have stuck. It slides back and forth and they have been known to stick.
Push it with a long screwdriver to see if it moves.
Solution 3:
Something is blocking the printer inside. It could be a paper jam or a foreign object.
Check using a flashlight, to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen.
If there is nothing obvious, unplug the printer power supply.
Dec 02, 2015 | Canon PIXMA MX882 Wireless All-in-One...
Keep getting error msg ink tank cannot be recognized after I replaced all ink cart
Hi
try removing/replacing all cartridges again - ONE AT A TIME. If that doesn't work, open the printer again and check which cartridge LED is not on. Replace the 'LED off' cartridge with a new one.
good luck
Sep 18, 2014 | Canon PIXMA MX882 Wireless All-in-One...
Canon printer wont start after power outage
Confirm that the printer is still plugged into a working power outlet
try plugging this printer into a known verifiable working power outlet and then try powering it on
if it still doesn't power on I hate to say this but it would cost you more to get it repaired then for you to purchase new the current replacement model for the mx882 is the mx922(Amazon @ $99.00)
Mar 04, 2014 | Canon PIXMA MX882 Wireless All-in-One...
CANON MX882 PRINTER ERROR 5B00
Cancel printing, turn off the machine.Then clear the jammed paper or protective material that is preventing the Print Head Holder from moving, and turn on the machine again.
skype id :johnwalker800969
Oct 10, 2012 | Canon MX882 All-In-One InkJet Printer
Looking for a manual for canon mx882
You can download everything that you need for this printer from this link, just click HERE.
Oct 07, 2011 | Canon MX882 All-In-One InkJet Printer
I am getting a 6C10 Error on a Canon MX882 printer
This is a valve cam sensor error. Whats that you wonder? Well power up the printer and when you hear the motor start up ,pull out the mains plug. Open the main cover so you can see the printers engine. The carriage is where the printhead is and thats where you put the ink tanks. Slide the carriage all the way to the left. At the right end (where it normally parks) is the purge unit. This is where the valve cam sensor sits. I suspect you will find a lump on very inky paper sitting ontop of the purge unit. Remove it or whatever you find clogging it up and hopefully all will be well.
Good luck
Jul 10, 2011 | Canon MX882 All-In-One InkJet Printer
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Canon MX882 All-In-One InkJet Printer Logo
55 people viewed this question
old marine
old marine
