Question about Northstar Water Dispensing & Filtration
Adjusting water hardest
We have residue where water has set . Does the water need to be adjusted at a higher or lower pH?
mikedurland
  • 481 Answers
SOURCE: Amana TempAssure
a lower number = higher temperature
confusing isn't it! :)
let me know if you need more help
mike
Posted on Jul 02, 2008
  • 7 Answers
SOURCE: BLACK BOX APPEARS IN LOWER
You have a closed caption setting turned on to text. Its probably near your channel up or down button. Keep pressing it, it will cycle through text1, 2, 3, 4, cc1 and cc2 and off. When you get to off leave it for a few seconds and it should disappear.
Posted on Jul 09, 2008
  • 185 Answers
SOURCE: convergence problem.
replace the stk chips
Posted on Dec 26, 2008
SOURCE: Adjusting headlights on 2003 honda accord
Further to Emmisionwiz's answer that worked for me - the holes are in the black plastic covering the radiator support, to each side more or less in line with the headlights. They are marked with an "A" and rotation directions for UP and DOWN. The Phillips screwdriver goes into the hole about 45 degrees from vertical and engages the adjusting rack, where the teeth of the Phillips screwdriver are the pinion. If you shine a flashlight down the hole you can see the rack teeth and all becomes clear. But you will need a long Phillips screwdriver and a little bit of luck.
In the owner's manual it says the lights are adjusted correctly at the dealership and if they need adjustment because of a trailer then take the car to a Honda certified mechanic.
I have a 2004 Accord also and the method is the same for that one too.
Posted on Feb 08, 2009
fixyourboard
  • 310 Answers
SOURCE: Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Posted on Jul 23, 2009
Adjusting of temperature setting
Hello Brian, Usually the higher the number the lower the temperature.
Aug 02, 2015 | Refrigerators
How do I correct my pond water's ph it is 5.8 ??
That is very acidic. Swimming pool supply stores will have powder to raise ph.
Sep 14, 2014 | Garden
Blue water stains in shower
Blue water stains are not caused by hard or soft water. Blue water or bluish green water is caused by the PH of the water. Low PH can corrosion of plumbing (copper lines) causing bluish green water or water high in alkalinity/PH can cause the same issue. Therefore there is no adjustment on the softener to correct this. I suggest a PH test to see what it is. If the PH is 6.5 or lower a calcite filter is recommended to raise the PH.
RJH2O
Dec 03, 2012 | Measuring Tools & Sensors
Panasonic 61
have you tried the following on the menu :
-adjusting the contrast higher or lower
- adjusting the brightness settings higher
- changing the viewing mode, most will have different modes like, movie/theatre/sport etc
hope this helps!!
col
Jul 29, 2012 | Panasonic Televison & Video
Adjusting rear shocks to lower my 1999 road king
Sorry I do not go back that far so if the shocks are not air shocks you can likely adjust them by turning the spring to a higher or lower setting and if air shock you need a special shock air pump to raise ort lower the air pressure. Use of a regular pump will not be accurate and an air supply more than 50 psi will likely destroy the shocks in any case.
Jul 19, 2012 | Harley Davidson FLHR Road king Motorcycles
I run the filter pump then turn on the salt water system for 4 hours and test for the chlorine and it is always very low or no chlorine and the ph is always high
pH will always rise over time when using a salt generator. You'll need to periodically add acid to counteract this affect. As far as low chlorine levels try running the system longer...An average pools circulation system is setup to turn over the pool water once in about 8 hours. Running your system longer should lead to a higher chlorine residual and overall cleaner water.
John
Apr 26, 2011 | Intex Automatic Salt Water System for ...
How do I adjust depth
You can adjust the depth by adjusting the heights of the wheels and how far the lever drops the mower deck...
Adjusting the wheels higher will allow the deck to go lower...
heatman101
Apr 23, 2011 | Garden
Adjusting pressure
The smaller "differential" nut you turn down for higher cut-out pressure or up for lower cut-out pressure. The bigger "range" nut you turn down for higher cut-in pressure or up for lower cut-in pressure.
Dec 13, 2010 | Square D FSG2J24M4CP Water Pump Pressure...
I have a nespresso latissima machine,Got it for x-mas, and now there is constant yellow light on the water (the tank is full, and there is a blue light when it is time to fill it up...) What does it mean?
I just had this same problem with my brand new Latissima premium and I fixed it by adjusting the water hardness setting. The yellow water warning light being constantly on means the machine thinks the water is too hard and the machine needs descaling. In my case, the machine just needed to learn how hard my water actually is. In the manuals that came with the machine you should have been given a ph testing strip and there are instructions in the user guide about how to adjust the water hardness settings. As soon as I did that, the yellow hard warning light immediately went off. In my case the water setting needed to be adjusted to the 7-14 ph setting. I'm attaching pics of the water hardness setting instructions from the manual.dberlyne_3.jpgdberlyne_2.jpgdberlyne_1.jpgdberlyne_0.jpgdberlyne.jpg
Dec 28, 2009 | Nespresso C190 Espresso Machine
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Water Dispensing & Filtration Logo
67 people viewed this question
Top Northstar Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Northstar Water Dispensing and Filtration Expert? Answer questions, earn points and help others
