Question about Maytag Atlantis MDG7400AW Gas Dryer
Dryer difficult to get started
Sometimes the dryer doesn't want to start with a load of wet clothes. I tried putting the wet clothes directly over the moisture sensor (black piece with 2 metal strips inside the dryer) and most of the times that does the trick. The clothes sometimes are still a little moist after the dryer stops and it is near impossible to get it to start again unless I put the moist clothing directly over the metal bars.
I suspect that there might be softener build up over the years on the 2 metal strips on the sensor. I've seen this part for sale in a few online parts store for $7 or so, but the shipping will make it about $14. I will check out the local parts store and replace it. I heard that you probably could wipe the 2 metal strips down with alcohol or Windex to remove the build up. I'll try replacing it. It's cheap enough and I can probably do it myself.
  • 64 Answers
All you need to do is take some real fine sand paper and sand it down litely
Posted on Jun 23, 2009
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
Whirlpool duet dryer model # GEW9200LW1, when powering up goes directly to touch up, and will not start. thermal fuse ok
Dirty moisture sensing strips? Have you tried cleaning them with windex?e03f8f0.jpg
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 11, 2010 | Whirlpool Dryers
My daughter in put a load of wet clothes (not completely finished spin cycle). Now dryer doesn't heat the clothes but seems to have all other functions.
Try running the dryer empty to see if the elements are heating. With the weight of wet clothes it is possible to trip the overloads.
Jan 03, 2010 | Dryers
Once we put a load of wet clothes in the dryer after about 3 minutes the dryer shuts off. The top of the dryer becomes extremely hot. We open the dryer door and let it cool down and then the dryer starts...
Wet clothing doesn't allow proper ventilation while tumbling clothes. This in turn causes electrical shorts: steam in chamber and reduces airflow. Reduced airflow will will cause the drier to shut off on an over temperature condition. Moral of story, spin clothes as dry as you can and when tumbling, make sure you have good ventilation to get best results.
Sep 26, 2009 | Dryers
Dryer model # RES7648JQO Serial # MK2707517 I put up a load of clothes to dry and when the cycle is done the clothes are still wet and there is water on the door inside the dryer. I've tried adding a...
it sounds like an airflow problem. check everywhere the air flows. inside the lint catch. the vent behind the dryer may be clogged or kinked. the exhaust line in the floor or wall of the house might be clogged. 689b12c.jpg
Aug 01, 2008 | Roper Dryers
Dryer shuts off prematurely
The E1 code is a replace control panel code and a good way to check a sensor is to open the door with a empty machine and at the top of the opening there is a switch. Press it and start the dryer, watch the indicator for the sensor then get a wet finger and hold it across the two silver bars in the dryer, if it senses then maybe it is a mixed load or how is the machine leveled? I will lower the machine toward the sensor for better contact because after 3-5 passes the machine will assume the clothes are dry. If the sensor doesnt read then there is a question with the two mov varistors attached to a pig tail before the sensor. Here is a link to see what they look like.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=529092&PPStack=1
May 04, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
100 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
