Question about Sirius Satellite Radio Sirius Sportster SP-R1 Satellite Radio Receiver
Doesn't receive and displays "acquiring signal"
    President:
  • 1,114 Answers
The "hideaway tuner" is bad. On the antenna input board there is a cold solder joint and it looses it's ground. If it's out of warranty you can get a rebuilt tuner on Ebay for about 50.00 This has been a huge issue among sat radio users for the past three years. The rebuilt units are better than the new ones. Hope this helps
Posted on Jun 24, 2009
SOURCE: Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Posted on Jun 06, 2009
SOURCE: sirius sportster sp-tk1, always displays "acquiring signal"
Same problem in RI too. Acquiring signal stays on the screen 24/7. My husband has the same Sportster. When I plug his into my car docking station, it works fine. When I plug mine in, it says "Acquiring signal". Does this mean my radio is dead?
Posted on Jan 06, 2008
  • 20 Answers
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Posted on Feb 20, 2008
  • 4 Answers
SOURCE: Acquiring Signal
Try resetting it to defaults if you haven't done that yet. I had a similar problem with a Stratus 4, and that took care of it for me.. Sounds like perhaps some kind of NVRAM gets corrupted and a full reset clears it up.
Good Luck. Hope it helps you like it did me.. Just remember to jot down all your presets first, because you will need to reset them.
Posted on Jun 12, 2009
  • 3 Answers
SOURCE: The display reads "acquiring signal" and three bar...
www.tssradio.com can help you fix it.
Posted on May 19, 2010
Second level tv has a signal but the main tv on first floor has no signal.
Hello! It sounds like there are a few things that could actually be going on. If you are getting no picture on the TV(you have a black, blue, or snowy screen), you will want to make sure that the TV is on the correct channel and/or input. You will want to be on channel 3 or 4, and possibly on a Video 1 or 2 or HDMI 1 or 2 input. If that doesn't work, then try unplugging the receiver from the power source for about 10 seconds. If you are still not getting a picture, let me know!
If you have a signal loss message on your screen (Signal has been lost, Partial SIgnal loss, COmplete signal loss, or Acquiring signal), you will first want to unplug the receiver from the power source for 10 seconds. You will get the Acquiring singla message as the receiver reboots after you plug it in, but that should only be about 5 minutes at the most. If you get the message after 5 minutes, you will want to make sure that all of the cables going from the back of the receiver to the wall are tight. If that still doesn't do it, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Acquiring satellites
The problem might be that your GPS is not able to connect to the satellite.
I'll see what the problem might be.
Mar 15, 2008 | Garmin nuvi 350 GPS Receiver
We have a dual transmitter DVR and TV 2 is not getting a signal.
If you're not getting a picture try this link it should help.
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Jan 20, 2011 | DISH Network ViP722 DTV Receiver /...
Can't get EPG to display after set up
johnandja460
You haven't specified which type equipment you are experiencing the problem. With our DISH Network receivers, if the EPG does not display you can do 1 of 2 things. First, unplug the receiver from the electrical outlet for 10 seconds and plug back in. This causes the receiver to reboot and re-acquire satellite signal. Then it will download the EPG.
If you still don't have the EPG, you can then run a check switch test. Press the Menu button on the remote. Main Menu will display on the TV screen. Press 6 (System Setup), 1 (Installation), and 1 (Point Dish) on the number pad. Highlight the Check Switch button on the right of the screen and press select. On the Installation Summary screen, highlight the Test button on the bottom left. Press select. The receiver will perform a switch installation check. After the test is completed, exit out of all screens till you are back to the TV screen. The receiver will acquire satellite signal and download the EPG. I hope this helps.
Ray Calo
DISH Network
Jan 19, 2011 | Sony Televison & Video
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
Drops signal as soon as location changes
You may have a dead zone in lake area !! I experianced alot of signal lose on a lake in oklahoma last year !!! swampratt200 !! AAEEE!!!
Jul 21, 2009 | Sanyo CRSR-10 SIRIUS Radio Receiver with...
The GPS cannot get satellite signal. It only displayed "acquiring satellite" considering that we are in open fields with clear sky.
Shut off the Receiver...
Press and hold Page + Menu + Power...
Then select "Yes" to erase all user data...
Leave it on with a clear view of the sky without moving for about 30 minutes to acquire the satellites.
Nov 28, 2008 | Garmin GPSMAP 60CS GPS Receiver
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius Satellite Radio Sirius Sportster SP-R1 Satellite Radio Receiver Logo
1,052 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tom Chichester
Justaguy
Level 1 Expert
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
